RV.Net Open Roads Forum: Class C Motorhomes: Sagging headliner
 > Sagging headliner
BillHoughton
West of the Mississippi
Posted: 03/11/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
The headliner on our 2007 Itasca Navion is sagging:
I'll be grateful for advice on how to reattach it, and also for any advice on whether this Means Something (say, water leak), or if it's just age.
Mojave, Kern County, CA
Posted: 03/11/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Cut an edge and look and feel for a leak.
jdc1
Rescue, Ca
Posted: 03/11/20 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Gotta peel it off and spray glue it back on. Better left to an auto upholstery shop.
ksg5000
Oregon
Posted: 03/11/20 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
I would be concerned that you have a leak vs just age. I have had car headliners sag but usually ten years older than your rig. I would make some calls to auto upholstery outfits and discuss whether they fix sagging liners and have any experience with RV's.
Kevin
1995brave
San Antonio, TX
Posted: 03/12/20 05:51am Link  |  Quote  |  Print  |  Notify Moderator
This could also be caused from the foam backing deteriorating from wrong type of foam or adhesive being used.
bobndot
Posted: 03/12/20 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I agree. This was a common problem back then.
There were a few fixes that you can view on the Winnie owners forum. Gluing using 3M or stapling marine carpet in place after removing the old stuff were common fixes.
Being that its a tight area to work in I would try a professional auto upholstery shop .
IAMICHABOD
Sunny So Cal 90713
Posted: 03/12/20 09:54am Link  |  Quote  |  Print  |  Notify Moderator
I will also go along with this,it happened to my Winnie,the foam backing deteriorated and the fabric sagged. It had to all be removed,a very messy job. It was replaced with the carpet type that is now in most RVs
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
BillHoughton
Posted: 03/12/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, everyone. I wrote Winnebago, too, and got this useful answer this morning: "We have seen instances like this where the headliner adhesion has let loose. Unfortunately, the only way to make a proper repair is to remove the old fabric and glue up new fabric or just replace the whole panel with the fabric already glued to luan paneling. This can be quite the task depending on how much fabric is coming loose from the panels. Depending on where and how much it is falling, you may be able to secure it using batt strips, upholstery tacks or rosettes. Those are just a couple of options that we have heard other owners doing."
This implies that there is something up there to which I can attach screws/tacks. Well, that'll be another fun project, unless I succumb and let an upholstery shop invade my wallet.
IAMICHABOD
Sunny So Cal 90713
Posted: 03/12/20 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
As I said before on My Winnie I had the same problem,there is Lauan under the fabric and I first started with the Headliner Repair Caps they screwed into the Lauan and worked for a while. The problem was that the it started in a very small area but as time went on the foam and adhesive just started to come loose in larger areas. It is a stop gap that may work out for you if it doesn't get any larger.
If it does then you may have to do as I did and take it all down.
Good luck!
ron.dittmer
North-East Illinois
Posted: 03/12/20 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
Our 1984 Toyota Mirage had the "bed curtain" thing going on. It all came down during the course of one trip. The foam backing turned to dust and just let go all at once. We sold the rig like that. Fortunately there were cabinet and trim features that held most of it in acceptable condition, but not well enough in the cab-over area.
Here are a few pics I took for the sale ad.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
 > Sagging headliner
