RV.Net Open Roads Forum: Tech Issues: Slideout relays
 > Slideout relays
Ctrueit
Canada
Posted: 03/15/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know where these are located on a 2004 255rlds wilderness advantage
ScottG
Bothell Wa.
Posted: 03/15/20 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
If a rack and pinion system, they dont usually have them. The switch carries the entire load.
Do you by chance need a switch?
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
LadyRVer
Posted: 03/15/20 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know on your unit, but I had one in a storage bay, behind a panel at the rear, maybe 6" tall by 12" long. Two relays (one slide out.) Had to look for it.
BB_TX
McKinney, Texas
Posted: 03/15/20 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Electric slides or hydraulic?
Ctrueit
Canada
Posted: 03/15/20 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
Electric slides, must have relays or a controller , as wiring at switches is to light to carry the load which means there has to be relays or a controller
Edd505
Elephant Butte, NM
Posted: 03/15/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Check near the battery, mine are in the front basement compartment, battery is on the other side of the wall. Just replaced one when slide would start and stop. They are normally auto resetting but yours could be manual reset.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Wherever I happen to park
Posted: 03/16/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Gee that's not how mine work.
I have the Power Gear Rack and Pinion.. and the manual. What I did not have till recently is the location of the QWE#$ P@_(*#OU${@# Controller (That's called a ding bat and is the printer's equivlent of the Broadcasters BEEEEEP out of bad language).
The switch tells the controller what it wants to do the controller monitors current to tell the motor when to stop.
IN my case .. Well I won't tell you as they put it in a stupid spot. I'd have put it near the motor. they put it over 10 feet away
How I found it
I got a Cable Tracker from Harbor Freight
Cut the lead to the motor and hooked up the transmitter
Beep beep beep got to a "Y" in the bundle and followed the wrong branch NO BEEP. went back and followed the other branch BEEP BEEP and 2 or 3 Y's later there was the controller board WOW.
Home is where I park it.
ScottG
Bothell Wa.
Posted: 03/16/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
How I found it
Some are clearly different but many, including the last two RV's I've owned, just used the switches with no controller or relays involved.
road-runner
Oregon
Posted: 03/16/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Some electric slides use a relay and/or controller, and some don't. Those that don't have a relay use a polarity-reversing switch wired directly to the the slide motor. In a trailer, the system "might" use a relay and/or controller. In a motorhome, it "probably" does. If you're able to see the back of the slideout switch, that will give a clue. If it's a double pole switch with 4 or 6 lugs, it's likely a polarity reversing switch wired directly to the motor. Short of just figuring it out, the OP is doing the right thing asking for somebody who knows with the exact model rig.
2009 Fleetwood Icon
jdc1
Rescue, Ca
Posted: 03/16/20 11:27am Link  |  Quote  |  Print  |  Notify Moderator
What do these relays look like (for future reference)?
 > Slideout relays
