RV.Net Open Roads Forum: Tech Issues: Slide out Problem
 > Slide out Problem
SARGUY
North America
Posted: 03/16/20 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Just went to check on my 5th wheel today and noticed that the bedroom slide was extended out about a foot or better. This also happened last year but only extended a couple of inches on that occasion. Any one got an idea why this is happening?
lryrob9301
Mid-Atlantic
Posted: 03/16/20 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a hydraulic slide, the retract solenoid is bleeding off pressure and needs to be replaced.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
Old-Biscuit
Verde Valley
Posted: 03/16/20 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
YEP^^^^^^
And if electric the clutch/brake is slipping
SARGUY
North America
Posted: 03/18/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the quick replies,I think its a hydraulic slide,its a Forest River Cardinal 5th wheel. I assume that the soleniod would be under the bed with the slide mechanism so will get a look at it soon. I imagine that there will be some evidence of fluid leakage, is that correct?
MrWizard
Traveling
Posted: 03/19/20 12:17am Link  |  Quote  |  Print  |  Notify Moderator
Internal leak loses pressure
No external signs of fluid
Solenoid valve will be on manifold at the pump
That drives the slide that maybe under the slide or might not
Radiate The Happy
1997 F53 Bounder 36s
fj12ryder
Platte City, MO
Posted: 03/19/20 07:12am Link  |  Quote  |  Print  |  Notify Moderator
There could be fluid visible if a fitting on the pressure side is leaking. Granted it is as likely it's an internal leak. Best check under the bed, where the hydraulic cylinder is located, too.
Howard and Peggy
"Don't Panic"
Weldon
Posted: 03/19/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
It could very well be you hydraulic ram is defective. You may have a leak of pressure in the hose or connection under the bed. If the ram is bad it may be losing pressure inside the ram. How old is the 5th wheel?
SARGUY
North America
Posted: 03/21/20 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
The 5TH wheel is 14 yrs old so its getting up there but it is in very good condition.I have had it since it was new so I know its been looked after, this is actually the first time I have had a problem other than replacing the TV and Stereo which were low quality items anyway. Just replaced tires, battery and propane tanks last fall.
Weldon
Posted: 04/10/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is 15 years old and I had the same problem with the bed slide. In my case the ram needed to be rebuilt for the bedroom and living room slide. If you had a bad leak from a hose this could be the problem. I was able to remove both rams and had a local person rebuild for me, then I reinstalled.
 > Slide out Problem
