RV.Net Open Roads Forum: How how do I find my tongue capacity?
Open Roads Forum  >  Class C Motorhomes  >  B+
 > How how do I find my tongue capacity?
DrewE
Vermont
Posted: 03/18/20 12:37am Link  |  Quote  |  Print  |  Notify Moderator
How much farther out is the motorcycle's CG from the point a trailer ball would be at? Extra distance there means extra torque on the hitch, which I think would imply some derating of whatever the factory tongue weight rating is. How much derating is a bit tricky to determine offhand; it depends on where you figure the axis of rotation would be for the torque applied, and what its limitations might be, etc.
Also be aware of the effect this would have on your wheel loadings; the load on the rear wheels will increase by more than the weight of the motorcycle (and the front wheels unload some) due to the leverage due to the rear overhang of the motorhome. If you're fairly close to the axle rating already, you could easily go over.
(Based on carrying a bicycle on a rack on the back of my motorhome, the motorcycle would not stay any too clean!)
FunTwoDrv
NC
Posted: 03/18/20 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Way back in our earlier years we had a 250cc Yamaha we carried on a 20' C. Although it was probably only about 200#'s, when mounted on the back it made the steering a bit "light"feeling. We finally moved it to the front bumper and handling was far better.
Gary
