RV.Net Open Roads Forum: How many times can you torque bolts on a hitch?
 > How many times can you torque bolts on a hitch?
mapguy
Puget Sound
Posted: 03/19/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Technically you can't buy a Grade 8 bolt in a metric size. I suggest you look for Class 8.8 minimum but think you would be better served with a Class 10.9 bolt. You probably will have to go to a real hardware store or a bolt supplier.
Belmetric is a quality online
business that has a wide range of metric bolts
Curly2001
Tucson, Arizona
Posted: 03/19/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
I will check to see if the directions say after the first 500 miles and let you know.
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
Curly2001
Tucson, Arizona
Posted: 03/19/20 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Just checked the instructions again and it says check torque after the initial 500 miles and at 1,000 miles thereafter. Not too happy about every 1,000 miles. Will order a new set of bolts and go from there. The new trucks are a real pain due to the bed height. I have to tow a little nose high now to keep the bed rail clearance.
Curly
Cummins12V98
on the road
Posted: 03/19/20 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Curly
Order? As in from CURT or somewhere you can get a higher quality bolt like mentioned above.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Curly2001
Tucson, Arizona
Posted: 03/19/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Will go to the local nut and bolt shop where they specialize in hardware. Large industrial supplier here in town.
FlatBroke
CO/AZ
Posted: 03/19/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Most bolts in an engine are torqued. The engine heats and cools thousands of times. How often do you re-torque those bolts?
Hitch Hiker
"08" 29.5 FKTG LS
Cummins12V98
on the road
Posted: 03/19/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
So what grade would you compare the CURT bolt to?
Curly2001
Tucson, Arizona
Posted: 03/19/20 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Gotta let the professional bolt guys compare and recommend replacements. These thread in a cast A arm that pins into the rails.
Curly
Cummins12V98
on the road
Posted: 03/19/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Curly
Take a bolt to a commercial bolt/hardware supplier and get a better grade.
mapguy
Puget Sound
Posted: 03/19/20 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Can't tell what the marking is on the bolt head in picture. IF 8.8 -this is a class 8.8 bolt. Class 10.9 would be marked "10.9".
