RV.Net Open Roads Forum: What size of fifth wheel to accomidate my 3/4 truck...
 > What size of fifth wheel to accomidate my 3/4 truck...
alboy
Kelowna B.C.
Posted: 03/20/20 09:00am Link  |  Quote  |  Print  |  Notify Moderator
ICBC INS CORP could give you a lot of trouble if you exceed your GVWR AND ARE INVOLVED IN AN ACCIDENT.You are held to that number,no exceptions,been there.
Cummins12V98
on the road
Posted: 03/20/20 09:14am Link  |  Quote  |  Print  |  Notify Moderator
So If I were a resident of BC with my 14k DRW that has a SAE rated RAWR of 9,750# and I loaded it to that and didn't add a single pound to my front axle weight of 5,250# bringing my actual loaded weight to 15k what would happen???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
TXiceman
Full Time RVer
Posted: 03/20/20 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Remember it all boils down to ....they make little trucks for little trailer and big trucks for big trailers. Get a trailer that falls within the manufacturers weight limits.
Ignore the folks that tell you I pull a bigger trailer with my little truck and they cannot give you any weights on the truck and trailer.
Ken
Amateur Radio Operator.
goducks10
There
Posted: 03/20/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Ken
x2
4x4ord
Alberta
Posted: 03/20/20 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Nothing. You'd never be pulled over and weighed because your headlights are not pointing to the moon.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Cummins12V98
on the road
Posted: 03/20/20 11:50am Link  |  Quote  |  Print  |  Notify Moderator
My point is how can one be fined when the actual SAE ratings are NOT being exceeded!
JIMNLIN
Oklahoma
Posted: 03/20/20 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing according to IBC motor vehicle act if you had 15k GVWR registration;
Maximum gross weight for axles
**7.16 (1) A person must not, without an overload permit, drive or operate on a highway a vehicle loaded or configured so that
(a) the gross weight on an axle exceeds the manufacturer's rated capacity for that axle or for the brake or suspension system with which the axle is equipped, ...**
And of course we know in BC you may register your truck at a GVWR which can be the sum of the vehicle mfg axle ratings or the vehicle mfg GVWR.
Most rv folks are assuming BC GVWR registration has to be the door sticker GVWR number.
4x4ord
Alberta
Posted: 03/20/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you were grossly over weight such that it was obvious that your frame was sitting on your axle bumpers BC law could weigh you and use the trucks gvwr number to validate their claim that you are over weight. It will never come into play with someone who is weighted to within their axle ratings.
bid_time
Michigan
Posted: 03/20/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
This:
19.11 (1)Unless operating under the provisions of an overload permit issued under the Commercial Transport Act, no person shall operate or cause to be operated a vehicle that is loaded in such a manner that the gross weight carried by any axle exceeds the gross weight rating for that axle as specified by the vehicle manufacturer, or the gross vehicle weight exceeds the gross vehicle weight rating for that vehicle as specified by the vehicle manufacturer.
(2)The weight distribution of a bus shall be such that not less than 25 per cent of the gross vehicle weight is on the front axle when measured on level ground.
(3)Subsection (1) does not apply to a vehicle
(a)manufactured before January 1, 2001, and
(b)having a gross vehicle weight rating of 5 500 kg or less.
clicky
* This post was edited 03/20/20 02:07pm by bid_time *
4x4ord
Alberta
Posted: 03/20/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
You might be right but what you're saying doesn't seem logical to me.... obviously things don't have to be logical to be legal. In Alberta we can register our vehicle for whatever number we tell them at the registries office. We can't exceed our registered weight but if we are registered for 100,000 lbs and our axle ratings are only good for 10,000 ..... The 100,000 lb registration number doesn't mean much. Conversely, if we are registered for 10,000 lbs and our allowable axle limit is 100,000 lbs the allowable axle rating doesn't buy us anything.
