RV.Net Open Roads Forum: Fifth-Wheels: Cut off switch with solar panels
 > Cut off switch with solar panels
4x4ord
Alberta
Posted: 03/19/20 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I bought 4x 100 watt solar panels and a Renogy Rover MPPT charge controller. The Rover manual states: NEVER connect the solar panel array to the controller without a battery. Battery must be
connected first.
So I guess I have to remember to remove the batteries I need to disconnect the panels first. I find this interesting because my father has been pulling his batteries out of his 5ver for winter storage for years and I'm sure he doesn't disconnect his solar panel to controller. Maybe the wattage of his panels isn't enough to fry the controler. I think this sounds like an accident waiting to happen. At some point someone will disconnect the battery to replace it or clean the posts and not know to disconnect the controller first. I guess it would help some to install a switch on the positive wire from panels to controller?
Edit: I was wrong. He pulls a fuse on the front of his controller when he removes his batteries.
* This post was edited 03/20/20 06:43am by 4x4ord *
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Ductape
On the Road
Posted: 03/19/20 07:38am Link  |  Quote  |  Print  |  Notify Moderator
That’s what most installers do. Might be a good idea to post a label by the battery terminals reminding techs to turn of solar switch -and where it is located- if you’re anticipating someone other than yourself working on it.
I turn my solar off before putting the coach in for repairs just in case.
49 States, 6 Provinces, 2 Territories...
2oldman
AZ
Posted: 03/19/20 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Maybe he's under cover..?
ppine
Northern Nevada
Posted: 03/19/20 08:58am Link  |  Quote  |  Print  |  Notify Moderator
You need a disconnect between your batteries and your controller. Put it on a board with your controller.
Mojave, Kern County, CA
Posted: 03/19/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I use a couple of tarps over my three panels then disconnect just to be safe. I don't want a busted controller. It was heck to get it installed in my pass thru storage comparment.
Old Days
Colorado
Posted: 03/19/20 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Can someone post a link of a good switch to shut off power from 270 watts of solar to the controller. Thank you.
work2much
Jackson Ca
Posted: 03/19/20 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Yes, most controllers need to have 12v power to turn themselves on and running solar panels to them without the battery connected isn't advised. On our Victron it emits the high voltage alarm to remind me.
It is a good idea to circuit protect the wiring anyway so I installed a blue sea circuit breaker between the roof combiner box and the solar charger to protect the cabling anyway. It is mounted inside the camper on our system as I like to turn off the solar once the LFP batteries are full or close to full. LFP doesn't benefit from a small trickle charge when full or close to full. This could be mounted anywhere between the panels and the controller.
[image]Click For Full-Size Image.
On the battery side I also installed a circuit breaker between the solar charger and the battery to protect that cable as well and to work on the solar charger if needs to be deenergized but I wish to keep the rest of the system live.
* This post was edited 03/19/20 12:54pm by work2much *
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2018 Jeep Wrangler Unlimited toad.
work2much
Jackson Ca
Posted: 03/19/20 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Something like this would be appropriate.
Circuit breaker
time2roll
Posted: 03/19/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
What is the voltage?
675w Solar pictures back up
jdc1
Rescue, Ca
Posted: 03/19/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/Ampper-Battery-Disconnect-Isolator-Vehicles/dp/B07JZ9NDH2
This is all you need.
