RV.Net Open Roads Forum: Travel Trailers: Battery maintenance questions
 > Battery maintenance questions
Matt1221
Posted: 03/20/20 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
We have had our rv set up since last weekend, the lady who initially did the walk thru told us we need to be keeping an eye on the liquid inside the battery weekly, she said it could dry out and start a fire if we didn't check it weekly.... Is this statement mostly true? and could you add some info to that?
Kern County, CA
Posted: 03/20/20 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Checking your battery water level weekly when camping is an excellent maintenance habit. Use distilled water and wear eye protection. Fill as recommended by the battery manufacturer. You might want to also read an RV Electricity 101 paper. I wouldn’t worry about fire but I would worry about extending battery life to the max. Them dang things are expensive.
Ron3rd
Upland, CA USA
Posted: 03/20/20 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Depends a lot on the weather. I check mine about once a month or so when it's warm if I remember. It's been cold and raining for the last 3-4 months so I haven't checked it at all. You'll get the feel of it.
You certainly don't have to check it once a week.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
jdc1
Riverside, Ca
Posted: 03/20/20 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
It's not going to start a fire...LOL. It'll just kill the battery. Put it on a trickle charger, instead of the converter it comes with.
time2roll
Posted: 03/20/20 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Generally if you are renting in place you should be able to just disconnect the battery and you will lose no water. Once a week does seem a bit much. Then do they expect you to fill the battery? Do you have distilled water and eye protection? Are you even comfortable topping it off? Easy to overfill also.
675w Solar pictures back up
kellem
Shenandoah valley,VA
Posted: 03/20/20 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Oh wow, misinformation.
I leave trailer plugged in year around and check water level twice a year.....never found it below the plates.
If it does however bother you, purchase an AGM battery as no maintenance is required.
beemerphile1
Ohio
Posted: 03/20/20 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
That information is wrong so it is probably safe to assume everything else you were told is wrong.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
midnightsadie
ohio
Posted: 03/20/20 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
some thing to add to your battery box,, a disconnect switch. this will shut everything off and your battery won,t drain down, this way when you go away for a week your battery won,t be dead when you return.
SidecarFlip
SE Michigan
Posted: 03/20/20 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Funny but oh so true. Anyone who believes a salesperson is pretty gullible.
Of course anyone who thinks You-Tube is gospel is in the same canoe.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
drsteve
Michigan
Posted: 03/21/20 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Unless your converter fails and boils the battery, you'll be fine checking the water level every couple of months. As for starting a fire... no.
When you check the water, be aware that the proper fill level is the BOTTOM of the ring. NOT the top.
1991 Palomino Filly PUP
