RV.Net Open Roads Forum: Travel Trailers: Solar Charge Controller question
 > Solar Charge Controller question
Twistedlarch
Cottage Grove, OR.
Posted: 03/21/20 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Here's my set up:
2018 Coachman Viking 17BHS 21'
Dual 6v batteries
Solar panels:
2 Nature Power 100 watt Polycrystalline panels
Tolerance: 3%
Voltage at Pmax(Vmp) 18.0V
Current at Pmax(Imp) 5.65A
Open circuit voltage(Isc) 21.6V
Short circuit voltage(Isc) 5.74A
Max system voltage 600VDC
Protection class Class A
I'm looking for a decent yet budget minded (Under $100) Solar Charge Controller to run my system.
Thank you!
Brian
Kern County, CA
Posted: 03/21/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Try WindyNation. A number of controllers under $100. I have two...one for floating when in storage and an MPPT.
jdc1
Rescue, Ca
Posted: 03/21/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/b/ref=DEX_NR_Covid?node=9433645011&pd_rd_w=YQLam&pf_rd_p=8ba1fd08-7860-44d7-b85e-7ca4028710d8&pf_rd_r=E67ZFDXT7ENHYZ181VEW&pd_rd_r=08f4818a-763a-4b36-80a4-a74e508c7f48&pd_rd_wg=FzCAv
Twistedlarch
Cottage Grove, OR.
Posted: 03/21/20 09:41am Link  |  Quote  |  Print  |  Notify Moderator
This link takes me to Amazon but doesn't show anything.
Twistedlarch
Cottage Grove, OR.
Posted: 03/21/20 09:46am Link  |  Quote  |  Print  |  Notify Moderator
This is one I'm looking at, but being a newbie to solar I would like to get a 2nd opinion, or other suggestions before I make a purchase.
Rich Solar 30 amp charge controller
Thanks
Brian
jdc1
Rescue, Ca
Posted: 03/21/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Renogy makes top notch 12v charge controllers. It's just a matter of how fancy you want to get.
dieseltruckdriver
Black Hills of SD
Posted: 03/21/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Watch this video, it will help you decide. I have a Renogy Wanderer and 320 watts on the roof of my 5er right now, and it works flawlessly. I am looking at changing and keeping the Wanderer for a spare.
Solar Charge Controller Buyers Guide.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Twistedlarch
Cottage Grove, OR.
Posted: 03/21/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
I'm confused with what I need, PWT or MPPT?
bob_nestor
murphy
Posted: 03/21/20 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Either will work, but a PWM one will be less expensive. The MPPT controllers can generally extract a bit more solar energy, but in a solar setup found in most RVs that advantage will probably be negligible and not worth the extra cost.
Ava
Vancouver Island. BC Canada
Posted: 03/21/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
I have a basic pwt controller from amazon that works fine for me. I have two panels with 120 watts total, charging 2 6v batteries with no problems.
