RV.Net Open Roads Forum: Travel Trailers: Solar Charge Controller question
 > Solar Charge Controller question
dieseltruckdriver
Black Hills of SD
Posted: 03/21/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Twistedlarch wrote:
I'm confused with what I need, PWT or MPPT?
Then watch THIS video.
My PWM works perfectly, but this is part of the reason I most likely will be changing. That and I want to get to at least 600 watts on the roof.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
pianotuna
Regina, SK, Canada
Posted: 03/21/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
If you decide on pwm look at the Grape solar controller available from Home Depot.
https://www.amazon.ca/Grape-Solar-GS-PWM........40BT-Controller-Monitoring/dp/B01FFNNUSK
or
https://www.homedepot.com/p/Grape-Solar-........rge-Controller-GS-PWM-COMET-40/305498558
Be sure to get and use the battery temperature sensor.
Regards, Don
Kern County, CA
Posted: 03/21/20 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
The Rich Solar unit is limited to 10 gauge wire max. That’s too small.
More charging power from an MPPT. Think cold, cloudy, wintertime, far from the Equator...and only 200 solar watts.
ScottG
Bothell Wa.
Posted: 03/21/20 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Great video and very helpful but I got a little lost. Can most of these switch between lead acid and LI if I later choose to upgrade?
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
2oldman
AZ
Posted: 03/21/20 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Only if they have user-defined voltage setpoints, including the ability to skip absorb. Cheaper ones usually don't.
What you may be able to get away with using Li's is that they don't care if they don't get fully charged, which may happen if you use the acid profile.
ScottG
Bothell Wa.
Posted: 03/21/20 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Good to know. If or when I switch over to LI, my solar system will be very small (if I even upgrade it) so I could probably get by with what I have.
ppine
Northern Nevada
Posted: 03/21/20 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
MPPT all the way. Get enough capacity in your controller in case you want to expand your system. I like a 40 amp unit.
I like Renogy and some other companies.
Windy Nation was nothing but trouble.
bpounds
Sophmore Brain...
Posted: 03/22/20 10:33am Link  |  Quote  |  Print  |  Notify Moderator
I've been very happy with my Epever system. Search that term on Amazon.
It will stretch your $100 budget, but worth the extra money IMO.
I would go with a 40a, even though the 20 or 30a would suffice for your 200w panel array. Unless you have zero chance of adding panels later, for example, no roof space left. In which case, go with the smaller rating CC.
I would also recommend the kit that includes the MT50 monitor that you can place inside the coach. The kit also gets you the temp probe.
Money spent on a PWM is money poorly saved IMO.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Boon Docker
Posted: 03/22/20 11:57am Link  |  Quote  |  Print  |  Notify Moderator
X2 on the Epever solar controller, excellent unit.
dieseltruckdriver
Black Hills of SD
Posted: 03/22/20 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
I am leaning towards the EPEver controller also, but may go with the Victron for a bunch more money just because I am so darn happy with my battery monitor.
The reason I am upgrading is I am already close to maxing out my Renogy Wanderer, and I have 200 more watts sitting in the garage waiting to be installed, and I really didn't plan on going this big to begin with.
It gets addicting being able to do everything we normally do without having to start the generator.
