RV.Net Open Roads Forum: Tech Issues: Theford toilet
 > Theford toilet
bsport
Kenosha WI
Posted: 03/21/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Aria II toilet had it replaced everything time to junk , any idea as what to replace it with ? Need same bolt pattern if possible.
Ed_Gee
Central Oregon coast - Winter in AZ
Posted: 03/21/20 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Dometic 310/311 or 320/321 . Keeps it simple, functional, excellent quality, ease of use, comfortable, and reliable.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Wherever I happen to park
Posted: 03/21/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
The good news is there are basically 2 bolt patterns.
Imagine a clock face over the hole in the floor with the 12:00 position pointed straight forwared as you sit:
One pattern is 3:00 and 9:00 (that's the 2 bolt pattern)
One is 3:00 9:00 6:00 and 12:00
The flange (The part in the floor) generally accepts either pattern.
Home is where I park it.
bsport
Kenosha WI
Posted: 03/22/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for help going to change as soon as I get home.
Ron3rd
Upland, CA USA
Posted: 03/23/20 07:45am Link  |  Quote  |  Print  |  Notify Moderator
X2
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
C Schomer
Pueblo West, Co.
Posted: 03/24/20 02:20am Link  |  Quote  |  Print  |  Notify Moderator
My wifey and I both have bad knees so I've been thinking about a hi profile toilet. I added a sprayer to my current toilet and a LOT of water goes down the drain when flushing AND using the sprayer... fresh water tank goes down and black water tank fills up fast! Does the Dometic with the mfgr. installed sprayer shut off the flush water when the sprayer is used? If not Dometic, does any other brand do that? Thanks,Craig
 > Theford toilet
