RV.Net Open Roads Forum: Tech Issues: 120 volt cigarette lighter size outlet
 > 120 volt cigarette lighter size outlet
opnspaces
San Diego Ca
Posted: 03/21/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I tried Amazon but I think my search parameters are wrong. I have a PSW inverter in the center console of my Suburban. I would like to run a short extension cord and mount an outlet in the rear of the console so the kids can then plug in to 120v. I'm envisioning something very similar to the link, only 120v instead of 12v.
Link
Has anybody ever seen one, do they even exist? I'm thinking it needs to screw in rather than snap in since the walls are curved not flat.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Mojave, Kern County, CA
Posted: 03/21/20 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Might be possible.
EV2
South Dakota/Arizona
Posted: 03/21/20 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Would that not be an extension cord?
Something like this :
Cord outlet
Or wire it yourself with this:
Outlet
opnspaces
San Diego Ca
Posted: 03/21/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for taking a shot at it, I just found what yo linked as well. I may need a short cord like that when this is all said and done. But I'm hoping to find a 120v outlet that will permanently mount in the center console.
The snap in might be where I'll have to go. But I would really like to find a round one that I can just drill a hole to mount.
EV2
Posted: 03/21/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Probably the only way to do it round would be to use a bulb socket on the inside and ‘this screwed in if you do not need a grounded outlet:
Adapter
Posted: 03/21/20 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Pumping 120 back to the kids without a traditional wall plug might be unwise. Their ages are?
full-timer
Where we park it, USA
Posted: 03/21/20 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Here you go.
https://www.zackelectronics.com/marinco-5279bl-15-amp-125-volt-flanged-outlet-receptacle-straight-blade-industrial-grade-grounding-black.html?
Dang it can't make a clicky.
An Indian and a Gypsy
Joe and Nancy
2002 34 foot Georgetown double slide Ford V-10
towing 2004 Chevrolet Cavalier 4 Down
Bobbo
Wherever I park
Posted: 03/21/20 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
full-timer wrote:
Here you go.
https://www.zackelectronics.com/marinco-........e-industrial-grade-grounding-black.html?
Made it a clicky.
Bobbo and Lin
opnspaces
San Diego Ca
Posted: 03/21/20 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks I might have to see about carefully trimming out a square hole in the console.
The kids are 14 to 21 so I'm not too concerned about the outlet. We have taken road trips for years with a 6 outlet power strip plugged into an inverter. But this causes me to have the power strip cable laying somewhere across the center console area. I've been thinking about this for years. I originally was going to run a conduit and standard household outlets in a box. But I was hoping to find something a bet more refined looking than that.
DrewE
Vermont
Posted: 03/22/20 12:13am Link  |  Quote  |  Print  |  Notify Moderator
Round sockets exist and are not hard to find with a bit of googling.
Maybe this one would work and not be too hard to buy? A box would still be required (or at least advisable), but if there's room behind the location in the console in the vehicle you could presumably rig it such that the console forms a sort of coverplate and so only need to make one big and two small round holes in it.
