RV.Net Open Roads Forum: General RVing Issues: New Camper problems
 > New Camper problems
Beaker
Brevard, NC
Posted: 03/21/20 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
You have a bad battery
I think so too. Went thru this last fall. It makes you think it's something else but when you jump the battery everything works.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
Flute Man
Payson, Arizona
Posted: 03/21/20 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
X2
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
hondapro
Central Pa
Posted: 03/22/20 05:16am Link  |  Quote  |  Print  |  Notify Moderator
Add me to the list,bad battery
Steve
2016 F-350 6.7 Diesel
2015 Springdale 311RE
Boomerweps
Hills of PA
Posted: 03/22/20 08:40am Link  |  Quote  |  Print  |  Notify Moderator
If you thought it was 240vac at the dealer, it was probably a 4 pole RV 50 amp 120vac system. RVs use 50 amp and 30 amp plugs. The 50 amp is TWO 120 volt supply legs that share a common return/neutral. So although it is called 50 amp, it actually totals 100 amps. The separate legs power separate busses (grouped circuits) so if one leg isn't supplied, its associated circuits and appliances are not either, like one air conditioning unit on one leg each when you have dual AC units. Most 50 amp RV adapters link the supply to both legs which means limited power to all circuits. You MAY not be sending any power to the converter to charge the battery.
Bottom line, your adapter may be hosing you.
Have you tried charging the battery disconnected from the RV, measure the charge, let it set a day, then measure the charge again to check the self discharge rate?
Edit: just reread thread. Brand new, take it back to the dealer to repair/replace battery. Brand new, dealer problem to solve!
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC
ramyankee
North Idaho/Kootenai Country
Posted: 03/22/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Cannot imagine the dealer would have put in an uncharged battery, BUT.
Rick and Patti ">
2 Proud Christian CONSERVATIVES ">
2002 Chevy Silverado, 8.1, Crew, LB, 3.73, 4X4
2020 Mesa Ridge 291rls
Now living in North Idaho (formerly Northeastern California) ... but the heart is with MONTANA STATE UNIVERSITY
travisc
Pacific NW
Posted: 03/22/20 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Take the battery somewhere go be load tested to confirm that
Winnebago Access 24V
SidecarFlip
SE Michigan
Posted: 03/22/20 09:13am Link  |  Quote  |  Print  |  Notify Moderator
One thing about Biscuit, he cuts right to it... Bad battery x 10.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Thermoguy
Graham, WA
Posted: 03/22/20 10:30am Link  |  Quote  |  Print  |  Notify Moderator
If you just bought it new from a dealer and something is not working, why not take it back to them? If they sold you a dead battery, they should change it. If there is a different electrical problem, they should fix it. Why spend the time troubleshooting? You did the basic, now let them figure it out.
Posted: 03/22/20 11:08am Link  |  Quote  |  Print  |  Notify Moderator
^What he said.
But more importantly, you need to learn how your rv works. Ben did a great job explaining it.
Sounds like only issue is a dead/bad battery.
Posted: 03/22/20 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Load test the battery. Don't understand how it took a charge but was dead.
