RV.Net Open Roads Forum: Fifth-Wheels: Installing an automatic transfer switch
 > Installing an automatic transfer switch
4x4ord
Alberta
Posted: 03/21/20 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I'm installing a transfer switch in my 5ver. The transfer switch has three sets of labelled terminals: Control; Power Cord; Generator.
It would be simple enough to just follow the labels but I want to hook the power cord to the transfer switch's Generator terminals as well as to "power in" on my inverter charger; hook my "inverter out" to the transfer switch's Power Cord terminals. Then Control will obviously go to the RV's breaker panel.
I guess it would work to follow the labels, but if I wire it as I am suggesting there would be no draw on my batteries to operate the transfer switch while running off inverter power. Is there any reason to wire it according to the labels?
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Flute Man
Payson, Arizona
Posted: 03/21/20 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
My inverter contains it’s own transfer switch to operate the coach when the pedestal cannot supply power. That being so, My power cord and the generator are wired just like the transfer switch instructions that you have.
You may call me if you wish.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
time2roll
Posted: 03/21/20 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
No don't jump it over to both. Cord to Cord, Gen to Gen. Control(output) to the inverter charger input.
Inverter/charger output to the main panel or circuit you want powered.
Seems easy as long as all is 30 amps or all is 50 amps. A bit more complex if it is 30/50 mixed.
675w Solar pictures back up
4x4ord
Alberta
Posted: 03/22/20 12:00am Link  |  Quote  |  Print  |  Notify Moderator
My inverter charger is only 30 amps so I don't want to run shore power through the inverter charger's internal transfer switch.
Housted
Los Angeles, CA
Posted: 03/22/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I plug my shore cord into the inverter and thus the xfer switch functions normally....cord/generator/coach.
Has worked for years.[emoticon]
Housted
2015 Dodge 3500 Laramie 6.7 CTD Tow Rig Integrated ball with Andersen Ultimate 5th Wheel hitch
2011 Arctic Fox 29-5T 5th - 4 Pt Leveling, Disk Brakes, 1050 W Solar,
300 Amps of LiFePO4,3000 Watt Inverter
  • pic
    Too many mods to Truck and trailer to list.
  • time2roll
    Posted: 03/22/20 10:47am Link  |  Quote  |  Print  |  Notify Moderator
    What inverter/charger do you have?
    Not sure you can use the charging function and block power from passing through.
    4x4ord
    Alberta
    Posted: 03/22/20 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
    I have a XantRex Freedom 458. If I wire as I explained in my first post I'm quite sure it would work just fine. The Xantrex input would be powered up from shore power through the parallel connection at the transfer switch. The inverter ac output would come into the transfer switch Power Cord input. Shore power, being connected to "Generator in" at the transfer switch should open the "Power Cord" circuit. There may be something I'm overlooking but I'm confident enough to give it a try unless someone can explain why it won't work.
    time2roll
    Posted: 03/22/20 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
    Yes that should work. I misread you had a generator in the mix. If the TS has a time delay you will pass power through the 458 until the TS activates. Some allow delay function to be disabled.
