RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel hitch lift
 > 5th wheel hitch lift
twodownzero
NM
Posted: 03/22/20 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Not everyone has access to a hoist or cherry picker and any lifting equipment
Anyone with a 5th wheel already has a lfting devcice....the 5vr front landing gear
I pull the pins on hith bedrails...raise the front landing gear lifting the hitch up via king pin high enough to clear truck bed then drive out from underneath it.
Repeat in reverse and set hitch back down onto bedrails...
Hitch hangs from king pin w/o issue.
This
4x4ord
Alberta
Posted: 03/22/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Not quite sure why my "NEXT" B&W will be lighter???
My current RVK3600 25k/6,500# pin weighs in at 229#. Base is 154# and head is 75#.
Hehe...I was just getting at the fact that you might want the same 153# hitch that Ford Truck Guy has after purchasing your next truck.[emoticon]
* This post was edited 03/22/20 05:36pm by an administrator/moderator *
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Cummins12V98
on the road
Posted: 03/22/20 10:32am Link  |  Quote  |  Print  |  Notify Moderator
NOW ...... I get it!!!
* This post was edited 03/22/20 05:37pm by an administrator/moderator *
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Allworth
Orlando, FL
Posted: 03/22/20 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Been hanging mine from the trailer pin for 15 years now. Never a problem.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 03/22/20 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
H e ! ! does have cold days!
Me Again
Posted: 03/22/20 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
I used my right thumb to remove and install mine along with the Demco picture frame as a single unit, along with a little help from HF. Chris
ford truck guy
Pennsylvania
Posted: 03/22/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
12V98 -
the NEW Companion single point attachment 20K is a bit heavier at 131# - base, and 75# for the head to total 206#.. capacities - 10k,,, 5k hitch...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Cummins12V98
on the road
Posted: 03/22/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
I just Man up and lift each pc in and out of my truck. I’m 62, last time I removed and installed I was 60.
ford truck guy
Pennsylvania
Posted: 03/22/20 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
I few years ago, I " manned up" removing my super glide in 1 piece...
Went into surgery the following week to repair a hernia... Thats that last time I did that... Up till this past year, if I needed to remove, I broke it ( Superglide ) down to as many pieces as possible... Head...Swivel...2 way tubes...base...rails.... [emoticon]. Live And Learn
* This post was edited 03/22/20 04:08pm by ford truck guy *
hornet28
Muskegon
Posted: 03/22/20 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
WOW didn't mean to stir up a hornets nest. For those who want the physical workout, have at it. Those that hang it from the trailer, I don't care to leave mine out in the weather. Those that leave it in the truck, I use my truck for other things so I don't care to have the hitch in all the time. Another way of looking at it is. You can work hard or work smart. I chose smart for this job
