RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel hitch lift
 > 5th wheel hitch lift
valhalla360
No paticular place.
Posted: 03/22/20 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for just lift with the front of the trailer.
Alternatively not hard to tie it off with a rope and lift.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
hornet28
Muskegon
Posted: 03/22/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Ok for you guys who feel the need to forgo lifts or such. Here's an example of working smart. In this picture is a 63" semi sleeper on my car hauler. I put it on there by myself no one around and no lift, hoist or fork lift involved. So how do you think I did it?
94-D2
Sutter Creek ca
Posted: 03/22/20 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Cribbing back the trailer under it.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
It’s not what you’ve done that commands respect, it’s what you do.
Happy Campin’
hornet28
Muskegon
Posted: 03/22/20 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
No the trailer at the fenders is wider than the sleeper.
4x4ord
Alberta
Posted: 03/22/20 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Lift one side up, drag it over to the trailer and set it on the deck, then go lift the other side up and push.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
hornet28
Muskegon
Posted: 03/23/20 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Way to heavy to lift and drag then lift and push. It was on a low cart with wheels, I rolled it next to the trailer, jacked it up and blocked it a few inches at a time. I used some 2x6 at the top to get it even with the trailer bed then I put some lengths of 1/2" pipe under it allowing me to roll it onto the trailer
richclover
WY
Posted: 03/23/20 07:17am Link  |  Quote  |  Print  |  Notify Moderator
I installed a B&W Turnover Ball in my Ram Cummins. Topped with the Anderson Ultimate.
Seemed like the easiest way to go...
Rich
2018 Ram 4X4 2500HD Cummins
2020 Chaparral 336TSIK
2019 RAM 1500 Classic 4X4 Hemi
2019 CanAm Maverick Sport 1000
SW WY
Learjet
Louisiana
Posted: 03/23/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I see that B&W has their own lifting device.
https://www.bwtrailerhitches.com/product/fifth-wheel-lifting-device
you can buy them here
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
laknox
Arizona
Posted: 03/23/20 09:19am Link  |  Quote  |  Print  |  Notify Moderator
hornet28 wrote:
I belong to three different trailering forums and don't remember where I saw a similar lift someone had built. I used the general idea of his and built this one. It fits into the hitch the same as the pin on the trailer. Lock it in place and use a cherry picker or overhead hoist to lift it and save your back. I just used what I had on hand
I found an eye bolt in my dad's junk pile, welded a 4" flat plate on the end of it, and used it just like you're thinking of doing. Found a cheap engine hoist to lift my Companion out in one piece then dropped it on a $10 furniture dolly from Harbor Freight. Sold the engine stand that came with the hoist, so was only out about $50, total.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Dave H M
IL
Posted: 03/26/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
We all need "something" to do. Keeps the brain cells moving!
Me, I just backed the fifth wheel into the barn yesterday and left the hitch hanging on the king pin.
however i did spend some time fabbing up a muffler for the 1948 Maytag two cylinder opposed. [emoticon]
