RV.Net Open Roads Forum: Travel Trailers: Water damage under shower.
 > Water damage under shower.
Baseballwife02
Central Florida
Posted: 03/22/20 03:22am Link  |  Quote  |  Print  |  Notify Moderator
Hi all! My husband and I just purchased a 2019 Forest River Salem 32 rlds. I was doing dishes and heard a noise.. ran to the bathroom and water was coming from under the shower. Turned everything off and opened the little panel to find my WORST nightmare. Water damage. There’s a hole cut under the subfloor that’s under the shower that apparently has been collecting water from longgggg before it was ours. I don’t even know where to begin with replacing this. Any suggestions or help would be appreciated. This is our first RV and we’re only 2 weeks in.
Also to add... I checked all closets, cabinets, floors around the area and the subfloor does not look to be damaged at all in those areas. Just the area that was cut under the shower.
hondapro
Central Pa
Posted: 03/22/20 04:52am Link  |  Quote  |  Print  |  Notify Moderator
How long ago did you buy it? Is it still under warranty? If so I would start by contacting the dealer where you bought it. Also you need to get the water dried up asap.
Steve
2016 F-350 6.7 Diesel
2015 Springdale 311RE
Gjac
Milford, CT
Posted: 03/22/20 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Can you tell where the leak is coming from? You need to do that first before you do any repair.
Kern County, CA
Posted: 03/22/20 08:01am Link  |  Quote  |  Print  |  Notify Moderator
X2 on hondapro’s comment. PRONTO!
It’s not clear if you were hooked to city water. Were you using a pressure regulator? This is why I fill the tank and use the pump.
William Willard
Brookins Oregon
Posted: 03/22/20 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Open the valve to the gray water tank -- Could e full & backing up into shower P trap -- Bill Willard
SidecarFlip
SE Michigan
Posted: 03/22/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you have some loose compression fittings in the drain line plumbing, pretty typical. I don't thing the Amish craftsmen know how to tighten fittings up. Had the same deal with my new one but I checked all of them before I ever used it. They were all either loose or had inadequate blocking under them or both.
Very typical, what I never buy used, only new but I go over everything before using the first time, I dislike surprises.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
ScottG
Bothell Wa.
Posted: 03/22/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
My first thought when ever I read this sort of thing is whether the manufacuter used plumbers putty fo rthe drain. If so, it wont last because it is not for use on plastics(sais so on the container). Use only 100% silicone.
I've seen numerous leaks in RV's and homes because of this mistake - often made by professional plumbers.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
wopachop
lb
Posted: 03/22/20 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
I just had the same issue with my Forest River. Remove the p trap and remove the drain. Then stick a blow dryer into the hole.
Will take a pic of mine. Its drying right now.
CavemanCharlie
Storden,MN
Posted: 03/22/20 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Don't panic.
It's hard to tell what you mean but, first, fix the leak ! Then dry the floor. If the only place that got wet is under the shower, the shower floor is still firm, and the rest of the camper floor is still solid then I would not worry about it.
But, that's just me. Little things happen. I don't worry about them.
Lynnmor
Red Lion
Posted: 03/22/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Some have the floor hacked out under the shower so bad that there is little support. Then the drain pipes might take the load and crack, ask me how I know. If you can't find the problem, then pull the shower base and do it right.
