RV.Net Open Roads Forum: 2004 Bounder New To Us Has Issues We Need Help With
 > 2004 Bounder New To Us Has Issues We Need Help With
davidandval
Michigan
Posted: 03/22/20 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
We have a recently purchased 2004 Bounder. The lights on the superslide were on in the listing but now that we have it non of the lights work. Have checked every fuse on the coach 3 times. I now have it at a small RV dealer that is also having difficulty finding the problem. Also, coming back from Florida we drained our water system due to driving into colder weather and when we stopped for fuel we noticed water seeping through the pargo wood flooring in front of the sink and shower area. Any one out there have any ideas? It would be very appreciated! Thanks in advance (:
gbopp
The Keystone State
Posted: 03/22/20 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check the slide for a pinched or cut wire?
Big Katuna
Deland, FL
Posted: 03/22/20 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a gas or a diesel? I ask as I have 05 DP.
Assuming DP, is the battery switch on? It’s by the front door on the EMS panel.
Chassis batteries charged?
My Kharma ran over my Dogma.
davidandval
Michigan
Posted: 03/22/20 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
gbopp, No, because so far, I havn't been able to locate any wires other then the lights themselves. It does sound like a logical possibility!
davidandval
Michigan
Posted: 03/22/20 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Big Katuna, It's a gasser. Chassis battery is charged.
craig7h
Branson MO area
Posted: 03/23/20 03:40am Link  |  Quote  |  Print  |  Notify Moderator
Really taking a stab in the dark, do any other lights in the coach work? If so its not the battery disconnect switch. If other lights do not work then do you get lights when plugged in? If so then it may be the battery disconnect switch or related items.
As for water leakage that may take more time and info to find the problem.
Itasca Meridian SE 36g
Road Master Tow Dolly
cavie
Posted: 03/23/20 05:32am Link  |  Quote  |  Print  |  Notify Moderator
Check the lights. They may have individual switches on them that are turned off. I am assuming that they all work on a single switch.
Under the coach you will find a junction box at one end or the other of the slide. Romex 120 volt wire and 12 volt wire will come to 2 different j-boxes. Coming out of theses boxes will be rubber cord to feed the slide and allow for flexibility. Remove the covers and check the voltage.
As for the water it would be a leak from under the sink. Not from the holding tank. Water does not leak up thru the floor.
zigzagrv
Nazareth, PA
Posted: 03/23/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
As far as the water leak is concerned, since your tank is empty. the only thing that could be leaking is the P-trap or possibly a water filter if you have one. Good luck.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
way2roll
Wilmington NC
Posted: 03/23/20 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Or a roof, or a window, or a slide...Are your other tanks empty? Was the bath roof vent left open and did it rain? Could condensation be coming in a roof vent?
As far as the lights, was this RV ever inspected to get tags? In any state I've ever lived, the clearance lights need to be working in order to pass inspection.
on edit:
Seeping through as in from the underside or you noticed water on the floor? Did you travel through rain? Did this model have pergo in it from the factory? Is it possible the previous owner replaced the floor to cover up an existing problem?
* This post was edited 03/23/20 03:22pm by way2roll *
Executive
Posted: 03/24/20 11:24am Link  |  Quote  |  Print  |  Notify Moderator
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
