RV.Net Open Roads Forum: Fifth-Wheels: Can a modified sine wave inverter damage rlectronics
 > Can a modified sine wave inverter damage rlectronics
Naio
Snug as a bug in a rug
Posted: 03/23/20 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have personally killed two Windows laptops with an MSW inverter.
I ran one of the laptops off the inverter for several days or weeks before the laptop died.
I had a backup laptop, different model from the same company, and it used to the same charger. I plugged the charger into Shore power, and charged my backup laptop with it. This killed the backup laptop. So the MSW inverter damaged the charger in some way that caused it to kill the second laptop.
My MSW inverter has a USB Jack that is active even when the inverter is switched off. I've used that to charge my phone a few times with no problem. Of course I don't know if doing it multiple times over time would be problematic.
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
2chiefsRus
USA Somewhere
Posted: 03/24/20 06:07am Link  |  Quote  |  Print  |  Notify Moderator
is it possible that not all MSW inverters are created equal?
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
4x4ord
Alberta
Posted: 03/24/20 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
I had a MSW Freedom 10 in to two boats and two trailers and never had a problem. Picked up a West Marine 1500 (AKA Freedom 15, which Heart Interface never marketed under their own label) and ran that for like 15 years on the last boat and never had a issue with anything running on it also. The Freedom units have great 4 stage battery chargers built in. They are worth it just for the charger.
That might be a good idea to keep the Xantrex for the battery charger and buy a cheap 2500 watt pure sine wave inverter to power the trailer.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
2oldman
AZ
Posted: 03/24/20 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Why do you advise cheap?
pianotuna
Regina, SK, Canada
Posted: 03/24/20 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Yes.
Ones that have a nice big heavy transformer tend to be better.
Small true sine wave under 400 watts have prices that went down like a stone.
My Favorite is the Victron. Sometimes on sale for $80.
Regards, Don
4x4ord
Alberta
Posted: 03/24/20 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'm just meaning I can purchase a stand alone pure sine wave inverter for much less than the cost of replacing my Xantrex inverter/charger.
time2roll
Posted: 03/24/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
I will always recommend separate components for inverter, charger, transfer switch.
675w Solar pictures back up
