RV.Net Open Roads Forum: Class C Motorhomes: Wheel Lugs
 > Wheel Lugs
Card35
Seguin, Tx
Posted: 03/23/20 11:14am Link  |  Quote  |  Print  |  Notify Moderator
New to Class C Traveling/Camping. Purchased a new JAYCO 31F, and Dealer kept emphasizing the importance of using a torque wrench frequently on lug nuts. Have done a lot of traveling over the years in various size 5th wheels. Did monitor lug nuts occasionally, but not to the extreme the dealer was suggesting. How often do Class C owners actually check and torque? Thanks for any help...
* This post was edited 03/23/20 11:43am by Card35 *
AF Ret & Enjoyin
2005 Cardinal 33TS/LX
2005 GMC 3500CC Dually 8.1/Allison
RDS 51g Fuel/ToolBox Combo
DrewE
Vermont
Posted: 03/23/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
I generally do the start of the season and any time I, or someone else, has removed or replaced a wheel for whatever reason (suspension/brake work for instance). Sometimes the start of the season one gets omitted. Tire pressure gets checked far more frequently.
As I understand it, they particularly want checks when the vehicle is very new to ensure that things don't get loose as they work into position or something roughly along those lines. In any case, it's not too hard to go around with a torque wrench and give each lug nut a push until it clicks. I think they recommend checking a bit more frequently when the vehicle is quite new, maybe?
2oldman
AZ
Posted: 03/23/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
I check mine often after a wheel has been reinstalled, but not with a torque wrench. Every 3rd or 4th trip I guess would be my routine.
SAR Tracker
Central Oregon
Posted: 03/23/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Take some red (or whatever color you prefer) nail polish, and dab a drop on the lug nut where it's against the wheel, after properly torquing. If the nut moves, the nail polish will shatter (it being lacquer). Alternative to THIS.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
jfkmk
NJ
Posted: 03/23/20 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I check the lugs with a torque wrench before each trip. Never had a lug loosen up, but still check. It takes me just a minute.
jdc1
Rescue, Ca
Posted: 03/23/20 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Just like the old new car (50's, 60's and 70's) head bolts, wheel studs stretch when new. So, yeah, for the first few thousand miles, check them more often than you would normally.
BarabooBob
Baraboo, WI
Posted: 03/23/20 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I check all of the lugs on my aluminum wheels after driving about 100 miles. After that, I may check them once or twice during the summer. I always use a torque wrench because my trailer requires 100 ft lb or torque and my truck requires 150 ft lb. That is pretty tight and I want to make sure I get it right without over tightening. If you over tighten the lugs on aluminum rims, you can distort the rims and that can affect the integrity of the rim. It takes very little effort to do it correctly and can cost so much (or get someone killed) if you do it wrong.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
ron.dittmer
North-East Illinois
Posted: 03/24/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Wow, I never check them, never thought of doing so on any vehicle I own.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
Dusty R
Charlotte Michigan 48813
Posted: 03/24/20 06:56am Link  |  Quote  |  Print  |  Notify Moderator
X-2
2oldman
AZ
Posted: 03/24/20 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Every tire shop I've been to tells me to check them at 50 miles after a wheel removal.
 > Wheel Lugs
