RV.Net Open Roads Forum: Class C Motorhomes: Wheel Lugs
 > Wheel Lugs
JKJavelin
Milwaukee, WI
Posted: 03/24/20 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Got 2 new rear tires for the truck while in Quartzsite a few weeks ago. After a couple hundred miles I checked them with a torque wrench. Almost all of the nuts moved a bit. I was surprised, as it seems most shops tend to overtighten them.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS--Now with Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 59 Nights
Posted: 03/24/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
ron.dittmer wrote:
Wow, I never check them, never thought of doing so on any vehicle I own.
That's because the recommendation to do so is not because a properly installed wheel with properly torqued lugs has the propensity to come loose on it's own, it's to lower the chance that an improperly installed or torqued wheel has enough time to come completely loose and cause damage or an accident. Or in more rare instances, a part or hardware has been over stressed, received physical damage or out lived it's useful life span, thus causing a condition.
For tire shops, it's a liability protection thing. "We told you to check the lugs 50 miles later...but ya didn't. Claim denied."
For private parties, it's a good thing to do to ensure the same thing. Didn't leave a lug loose or whatever.
To check lug nuts or bolts "regularly" is just paranoia or lack of comprehension. If you check your RV lugs weekly, do you check the toad weekly, the wife's Buick, the kid's car? Think about it.
And yes if you're worried about it, installing tattle-tales is way easier to check than hitting 64 lug nuts with a wrench "regularly."
Durb
NW
Posted: 03/24/20 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
I check mine maybe twice a season. I'm surprised at how many have loosened some. I take a lot of trips but don't tow a lot of miles.
pauldub
North of Seattle
Posted: 03/25/20 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I check mine immediately after I buy tires. I don't think I've ever found any under-torqued, but finding them over-torqued happens too often.
bukhrn
Lanexa, Va
Posted: 04/01/20 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Dusty R wrote:
X-2
x-3
2007 Forester 2941DS
2014 Ford Focus
klutchdust
Orange, California
Posted: 04/01/20 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Every tire shop I've been to tells me to check them at 50 miles after a wheel removal.
My guess is to double check their work. Remember, be sure you are using your torque wrench properly. snap check is the best way otherwise you may add a little bit of torque each time you check.
Do you back off your wrench in-between uses?
So far and wrenching for a living I have not found a torqued lug nut loose, now in heavy equipment is another issue.
klutchdust
Orange, California
Posted: 04/01/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
x2
I have removed tires from other cars not my own and wonder if they used a cheater pipe on the end of a breaker bar.
And i usually find that out on the side of the road with the OEM lug wrench/pry bar thingy as my weapon of choice.
My dad always had a 4 way in his vehicles. i carry a breaker bar and strong socket.
Jaxom
Eastpointe, MI
Posted: 04/01/20 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
jfkmk wrote:
I check the lugs with a torque wrench before each trip. Never had a lug loosen up, but still check. It takes me just a minute.
How can you check the lug nuts' torque? Mine is supposed to be 450 ft. lbs. or so. At work they have a clicker style torque wrench. It's about 5 feet long.
Jerry
2015 Jayco Seneca 36FK
2011 Jeep Wrangler Sport 2 door
2011 R & R 20' Aluminum Enclosed Car Hauler
2007 Montrose 16' Aluminum Flatbed ATV Trailer
 > Wheel Lugs
