RV.Net Open Roads Forum: Tech Issues: sceamig help for my 2000 rexall airbus
 > sceamig help for my 2000 rexall airbus
road warriors
Oak Harbor
Posted: 03/23/20 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
so sorry to everyone who replied and thank you for replying. I did a very poor job in posting my last post. I started with my water heater then jumped off track. I did finally call an R.V. mechanic for the house side of my R.V and after I had changed everything having to do with the heater it turned out to be a corroded wire from the darn propane tank safety valve. Now, the rest of the story. When I began working on the w/h my r.v. would run. Its a 2000 Rexall Airbus with the V-10 Ford engine. Gas type. 36 footer. But for some reason, now it won't start. So I naturally figured that I may have shorted something, fuse, relay, or made a horrible mistake. As it turns out the chassis side is totally different from the house side so it is improbable that my fear most likely is not the cause. Sooooo, I would still appreciate any help or suggestions that any of you may have. Again I am very sorry for my bad attempt to post. I did realize that I gave little info on my r.v. but I didn't know how to go back to my post and correct it. Thanks again
gbopp
The Keystone State
Posted: 03/23/20 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Details, we need details. [emoticon]
When you say it doesn't run do you mean it won't turn over, it clicks when you try to start it or it does nothing when you try to start it?
jdc1
Rescue, Ca
Posted: 03/23/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds as though you may have another bad wire.....grounding wire. Did that motorhome spend a lot of time near the ocean? I'm asking because salt water does a number on copper and aluminum, including wiring.
opnspaces
San Diego Ca
Posted: 03/24/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
At this point don't worry about trying to correct the old post. But in this new post you can just use the "Reply" button and add more information to help us help you.
What we really need to know is in your words what happens when you try to start the motor home?
When you turn the key do the dash lights come on?
If you turn on the dome light and then turn the key to start does the dome light go out?
When you turn the key to the start position do you hear any noises or clicks?
If you hear a click do you hear a single click or a series of clicks?
Do you hear the engine crank over but it does not start?
Does the engine crank speed sound sufficient to start? Or does the cranking speed seem low?
If you hear any other noises can you try to describe them and when they happen?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
road warriors
Oak Harbor
Posted: 03/24/20 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
everything sounds fine. It doesn't sound like a bad starter solenoid, all the dash lights and things that would make you think a bad ground, turns over just fine, strong battery, nothing dims when it's turning over, it just doesn't want to fire. I even tried a small shot of starting fluid, but it has fuel injection so I didn't want to press my luck. I have learned my lesson with that. In a way it sounds like it is not getting fuel, in the other way it sounds like it not firing at all. We have a place where we have it worked on about six miles away, plus towing insurance so I will probably just take it in when the virus thing lightens up. I like to try to fix things myself and learn cause I'm sure it will be a plus when we decide to hit the road. I'd still appreciate any ideas or suggestions. Thanks alot
MrWizard
Traveling
Posted: 03/24/20 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Borrow or buy. An OBDII code reader
And retrieve the codes from the engine computer
That will give you some clues nto what might be the problem
Like no fuel n pressure, etc..
Post those codes here, and members familiar with that engine can tell you the most likely common cause for that code from their experiences
Radiate The Happy
1997 F53 Bounder 36s
road warriors
Oak Harbor
Posted: 03/24/20 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
great idea. The last time I took it in to have it worked on, thinking it may be a catalytic converter problem, turned out to be the computer, I looked all over for that code reader port and could never find it. Supposed to be somewhere close to the steering column. Never did find it. I do have a "fixit" code reader so I will try7 again to find that port. Will let you know what becomes of this. Thank you Moderator
Matt_Colie
Southeast Michigan
Posted: 03/25/20 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Code readers and now cheap.
Real cheap gets you one that works with your smart phone. More money gets you one with a read out and a book of what the numbers mean. You can spend a lot more if you chose. They all work the same, they just tell what the ECU says it does not like.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
road warriors
Oak Harbor
Posted: 03/25/20 10:45am Link  |  Quote  |  Print  |  Notify Moderator
thank you Matt, I really appreciate it and I will definitely look in the that. Just called the place where the mechanic that worked on it last year, hoping to ask him where the port is and he happens to be off today. Darn the luck. Thanks again
RLS7201
Posted: 03/25/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
OBD-II port is under dash, probable clamped to the right side of the steering column.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
