RV.Net Open Roads Forum: Fifth-Wheels: Ground Control 3.0
 > Ground Control 3.0
rconkin
Jonesborough, TN
Posted: 03/24/20 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2016 KZ Durango 2500 D349BHQ. Last summer I had to replace the LF landing gear after just 3 years of use. After our last trip last fall I had unhitched and was attempting to raise the front some when the RF landing gear failed. The front of the camper dropped down when it failed and fortunately the leg was only extended a couple of inches at that point. DW was inside cleaning out the refrigerator and it was enough that it gave her a pretty good scare as she was afraid it had dropped on me. I ordered another new leg and just had the opportunity to replace it last week. When I disassembled the old leg I found that the gear in the top of the leg itself had stripped out. In the picture of the worm gear, what appears to be grease is actually the gears from the top of the leg. I have sent both KZ and LCI emails along with these pictures. I have heard nothing from KZ and really don't expect to as they have never replied to any other emails I have sent about this and another issue I was having in the past. I did receive a reply from LCI putting responsibility on KZ for deciding which units they put these on. My opinion is that LCI states the lifting capacity they are capable of and that is how the manufacturer decides what it can be used on. They were kind enough (sarcasm) to offer me 20% off on any parts that I might need. Anyway, I'm very dissatisfied with this system and would warn others not to purchase a 5er with this unless it is a very small one. Also, if you currently have this system and start hearing screeching when operating, I would stop right then. I am planning on drilling some holes in the outer portion near the top so that I can get grease to the worm gear as of now there is no way to do that. Has anyone else had similar problems with these legs/levelers?
12 Ram 3500 Longhorn Edition, CTD, DRW, 4X4, Tow Max, Andersen Ultimate Hitch, Double R Diesel MM3 tunes, Deleted.
"For those that fought for it, Freedom has a flavor that the protected will never know!" Semper Fi
Super_Dave
Harrisville, UT
Posted: 03/24/20 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
What is the material clogging the screw leg?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Birdnst
Poquoson
Posted: 03/24/20 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I cannot resist Dave did you not read th op
If you cannot take good care of what you have, you will not have anything good for very long!!!
laknox
Arizona
Posted: 03/24/20 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Be willing to bet that the rated capacity for the jacks is well within specs, and more than enough to do the job. Now, given that it's an LCI product, the actual construction quality of the jacks is suspect from the get-go.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
Lynnmor
Red Lion
Posted: 03/24/20 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
The nut looks like cast pot metal, can you determine what it is made of?
B.O. Plenty
Minnesota
Posted: 03/24/20 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Considering most of the weight is on the wheels, the actual load on those front jacks isn't that high. Thousands of trailers have them and yes they do require some maintenance. They don't cost a lot and are easy to change.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Super_Dave
Harrisville, UT
Posted: 03/24/20 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I did but I guess it didn’t translate in my question. What was the gear made of?
* This post was edited 03/24/20 04:07pm by Super_Dave *
garyp4951
TN
Posted: 03/24/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Did you run them way out every time you set up, and not drop the inner legs? Just curious, but I have seen this posted before about not being able to grease them too.
rconkin
Jonesborough, TN
Posted: 03/24/20 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
It's definitely not steel and your probably right guessing pot metal. That's what I would guess.
rconkin
Jonesborough, TN
Posted: 03/24/20 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
B.O.
This is their auto leveling system where the two front legs work independently of each other. Depending on how level the site is, they will take some weight of off the tires sometimes. I don't consider $450.00 per legs cheap and that was the best price I could find on them. I had to buy the entire assembly which includes motor and gearbox. I don't trust them now and will return to putting boards under the tires to level side to side before hitting the auto level. Kind of defeats the purpose of having the auto level. There is nowhere to get grease in them without taking them off and disassembling them. That's why I'm thinking of drilling the hole and at least getting some grease on the gear above the leg that extends.
