RV.Net Open Roads Forum: Class A Motorhomes: Windshield seal
 > Windshield seal
C20
Shawnee KS
Posted: 03/24/20 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 08 Itasca, and the windshield seal leaks. It also came off when a truck passed me once and I had it put back on. It has since come off again, and I stopped and bought the 3M windshield adhesive and a new seal.
The seal is like the old one, but when I put it on it barely fits the gap. There is hardly any seal left to put the adhesive on. So that brings me to two questions.
Do they make a seal that is wider so more adhesive could stick to it?
Could I just fill the gap with the windshield adhesive, and then put a piece of Eternabond tape on it and not put the rubber back on at all>
This is the seal at the top of the windshield that I'm talking about. It goes from one side to the other in one piece.
Thank you all!
08 Itasca 40 FD
02 Jeep Liberty
16 HD CVO Street glide
2015 Challenger Hellcat
2016 Ram Eco Diesel
Bruce Brown
Northern NY
Posted: 03/24/20 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Any chance the structure is rusted out?
I haven't read of many lately but it used to be a common Winnie issue.
If it is you'd be better off removing the windshield and getting it fixed properly.
There has to be a reason for the issue you're having.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
C20
Shawnee KS
Posted: 03/24/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Bruce,
It is rusted. The last time I had a windshield put it it had quite a bit of rust on it. They got it put in but wouldn't guarantee that it wouldn't leak. The leak is intermittent, and not bad, but I'd like to seal it up. I thought that by filling the void with the adhesive then using tape instead of rubber it might make a better seal. The next time I need a windshield I'll take it to Winnebago and have them fix the rust and make it right
Bruce Brown
Northern NY
Posted: 03/25/20 04:20am Link  |  Quote  |  Print  |  Notify Moderator
Spray foam and Eternabond?
C20
Shawnee KS
Posted: 03/25/20 07:02am Link  |  Quote  |  Print  |  Notify Moderator
That might be a good idea!
georgelesley
Tennessee
Posted: 03/25/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
It is still a Winnie problem with our 2914 Winnie. I took the seal out, cleaned up and recaulked as best I could. Then glued and sealed the edges of the seal. Then covered the entire seal with 4” wide electrical tape( any good tape would work) and finally put a stick on gutter above the windshield to stop roof runoff from coming down
4 years later, no leaks.
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
 > Windshield seal
