RV.Net Open Roads Forum: Class A Motorhomes: Batteries on of off
 > Batteries on of off
Mtn.Mike
Ulysses
Posted: 03/24/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
This will be the first time that I leave the motorhome on the lot in Florida. What is the consensus on turning my coach and chassis batteries off.
I will be on shore power for the 6 months I'm gone and don't know it the batteries should be left on or off.
Any input would be greatly appreciated.
Thanks, Mike
2004 Holiday Rambler Endeavor pushed by a 2013 Mazda Miata
Mojave, Kern County, CA
Posted: 03/24/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
What is your controller’s make and model?
wolfe10
Posted: 03/24/20 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
You will need to tell us exactly what converter or inverter/charger you have.
If a smart one and will maintain the batteries at around 13.0-13.2 VDC leave it plugged in. Yes, that is where you want it in summer temps. Higher if cooler temps.
If not, disconnect, but in 6 months, expect their self-discharge rate to pretty well deplete them.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
opnspaces
San Diego Ca
Posted: 03/24/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a reason that you need to leave the coach plugged in for the 6 months? If the refrigerator is not going to be left running then there is really no reason to leave the coach plugged in.
But if you want to leave the coach plugged in to keep the batteries charged up, we would need to know the make and model of the converter/charger unit.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
dougrainer
Carrolton, Texas
Posted: 03/24/20 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Your year Model has an Inverter/Charger. Your Coach battery disconnect does NOT turn the batteries OFF from the Inverter/Charger. While plugged into 120 shore the Inverter/Charger will be trickle charging the coach batteries. Your year model, Monaco may NOT have optioned the Bi directional relay that would also trickle charge the Chassis batteries. Regardless, I would install a battery maintainer on the chassis for the months you plan to store. So, disconnect the Coach battery by the ON/OFF switch and your coach batteries will be charged and maintained. Use the link to see just one type of battery maintainer. Doug
https://www.batterytender.com/Battery-Tender-Junior-12V-0-75A
garym114
Bluff Dale, Texas
Posted: 03/24/20 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Just disconnect the batteries, no need for shore power.
Disconnect by removing the ground cable.
DrewE
Vermont
Posted: 03/24/20 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Six months (or even three months) disconnected in Florida summer temperatures will cause them to self-discharge a lot...most likely to the point of permanent damage. Six months in subfreezing temperatures is far, far less of a problem.
jdc1
Rescue, Ca
Posted: 03/24/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
And use a small trickle charger to maintain them.
time2roll
Posted: 03/24/20 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Top off the water and leave them on. Check that the chassis battery is actually getting a charge.
675w Solar pictures back up
ArchHoagland
Clovis, CA, USA
Posted: 03/24/20 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
Florida...First thing that comes to my mind is thunderstorms, then hurricanes, then tornadoes.
If it was mine it would NOT be connected to power.
I'd disconnect the fully charged batteries and then show up a day early to take it out of storage and charge the batteries.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
