RV.Net Open Roads Forum: Electric black tank dump valve. Worth it?
 > Electric black tank dump valve. Worth it?
ivbinconned
highway 16
Posted: 03/24/20 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Been having trouble with cable and valve leaking.
Took belly off once to deal with cable. Now valve leaking. Thinking if I have to take belly off again perhaps I should go electric.
Are they trouble free?
Ram and 34 ft Cedar Creek
K Charles
Connecticut
Posted: 03/24/20 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Bending over to pull the handle sideways made me get an electric one on our last TT some years ago. It worked very well and stayed on the TT when we traded it in.
gbopp
The Keystone State
Posted: 03/24/20 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I have visions of the valve shorting out and opening while rolling down the road. And, of course, there will be a police car behind you when it happens. [emoticon]
Kern County, CA
Posted: 03/24/20 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
When I can’t pull the black tank valve, it’s time to stop RVing...even if I still owe my soul to the company store.
Gdetrailer
PA
Posted: 03/24/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see where an electric valve would be more trouble free than a cable or direct mechanical manual valve.. They all wear out or have issues.
Perhaps time to see if you could relocate valve to a easier to get to location in order to eliminate the cable?
Alternate would be use a standard manual valve but attach a sturdy metal rod to the pull handle and bring that out to a location you can get to.. That would get rid of the flimsy cable setup..
down home
south
Posted: 03/24/20 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Absolutely worth it, in a number of scenerios. Our gauges are in the coach the valves in the bay. Need to wire gauges to a set in the bay.
But why just stop at black tank...which requires flushing by connecting a hose to the flush vale for both tanks an switching between tanks.If I was younger I would have remote controls to servos on black, gray, and fresh water fill/and supply switch valves..as well as aux water connection to flush valve.
one of it is hard to lay out just require a clean sheet of paper while looking at the plumbing and where to mount the servos/switches in the bay and power supply and remote switches inside where the gauges are. I imagine a Prevost conversion has all that all that already.
I have had to open the gray and black and flush them on a dark and stormy night and twern't any fun atall!
Dick_B
Palos Heights, IL USA
Posted: 03/24/20 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Seems to me this was recently discussed and I commented that the electric valve should have a manual override just in case.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Durb
NW
Posted: 03/24/20 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Electric dump valves were standard on my twelve year old fifth Wheel. They are outstanding when they work, not so good otherwise. They can be overridden with a 1/8" hex key which requires crawling under the trailer. Not the most fun at a dump station.
B.O. Plenty
Minnesota
Posted: 03/24/20 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
That's why it is required by law to have a cap on the end of the pipe.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
NRALIFR
Truck Camping Out West
Posted: 03/25/20 05:27am Link  |  Quote  |  Print  |  Notify Moderator
If you don’t have an electric dump valve, how are you going to dump your black tank while crossing a bridge over the Chicago River? Those poor people on the boat below! [emoticon]
Look out below!
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
