RV.Net Open Roads Forum: Electric black tank dump valve. Worth it?
 > Electric black tank dump valve. Worth it?
Veebyes
Posted: 03/25/20 07:53am Link  |  Quote  |  Print  |  Notify Moderator
The Drain Master system works great when it works. You don't want to know about it when it does not.
My 2007 Alpenlite had the electric valves from new. The grey valve has been trouble free for hundreds of dumpings. I have given up on the black valve & must open it manually everytime.
The fault is not so much the valve as it is how the valve was mounted. Out of necessity, because of a frame member, the valve is mounted 90 degrees off of vertical. Installation instructions specifically say mount it vertically.
Before you buy make sure that there is vertical space above the mounting location for it. It will work for awhile mounted incorrectly but then it gets partially jammed & need help with the manual Allen key everytime.
Between the DW operating the switches & I we have gotten very good at dealing with it, & spend far less time dumping than most people.
A huge time saver is that the system is self contained with the dump hose always hooked up & stored in a tube under the trailer.
2007 Alpenlite 34RLR
Cummins12V98
on the road
Posted: 03/25/20 08:30am Link  |  Quote  |  Print  |  Notify Moderator
I CHIT canned my cable valves and went to manual "T" valves that are EASY to push/pull.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ivbinconned
highway 16
Posted: 03/25/20 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Well you all have scared me off of the electric option.
My CC has cable...6 foot! The valve is mounted at 90 degrees from vertical. It has always been stubborn to move.
The whole thing is hidden from view as it is all above the belly panels. So operating an electric one “manually” would not be an option.
Thank you all. Including the comedians.
Ram and 34 ft Cedar Creek
Bumpyroad
Virginia
Posted: 03/25/20 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I would suggest installing a macerator pump at the same time, with a manual bypass feature.
bumpy
larry barnhart
wenatchee. wa usa
Posted: 03/25/20 10:05am Link  |  Quote  |  Print  |  Notify Moderator
simple is better and also why I like our 05 truck. Install the valve at the end where the cap is on for travelling and problem is solved. simple job.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Posted: 03/25/20 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Unless you're the 2nd poster and cant bend over to get to the valve due to personal physical limitations, en electric valve is a solution to a problem that doesn't exist and generally complicating a simple system.
Reisender
NA
Posted: 03/25/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Ours were problematic. We ended up replacing them twice over 9 years. We eventually switched to manual.
ivbinconned
highway 16
Posted: 03/25/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Larry this trailer does have another second valve fully exposed with/at travel cap. The grey water Valves also are hidden with in the belly then pipes all join before final valve.
So I do not like your idea because there are times when I dump grey water away into the grass or cactus when boon docking. I would loose that option if I don’t fix this valve.
fj12ryder
Platte City, MO
Posted: 03/25/20 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Just a thought: I do believe the bolt spacing is equal on those valves, so do you have space to rotate the valve 90°? Or secure the cable directly above the valve so the cable will have a straight pull.
Howard and Peggy
"Don't Panic"
MrWizard
Traveling
Posted: 03/25/20 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.. Electric is much better than cable operated,
There is an electric black tank dump valve on our previous RV a 95 Safari DP, it worked perfect for many years, eventually it leaked a little and there should be dirty water when i removed the cap, I added an external manual valve at the dump hose connection point
After a few more dumps and flushes, no more leak,
Apparently Some thing had clogged in the gate path, causing an imperfect seal, i left the external valve in place, and used both, the electric never did leak again
Radiate The Happy
1997 F53 Bounder 36s
