RV.Net Open Roads Forum: Electric black tank dump valve. Worth it?
 > Electric black tank dump valve. Worth it?
fj12ryder
Platte City, MO
Posted: 03/25/20 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
ivbinconned wrote:
Been having trouble with cable and valve leaking.
Took belly off once to deal with cable. Now valve leaking. Thinking if I have to take belly off again perhaps I should go electric.
Are they trouble free?
Consider a manual valve: you pull the handle, either a cable or a rod moves the valve, done.
An electric valve: you push a button, the button closes a circuit which may go through a circuit breaker or fuse, the motor is supplied electricity which then moves a rod or cable which moves the valve, done.
My thought usually is KISS. No way an electric valve is going to be more trouble free than a manual valve. Too many interconnecting parts add to the chances of a failure.
Howard and Peggy
"Don't Panic"
Lakeland Bob
Posted: 03/25/20 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I gather this subject is about "optional" electric drains on new RVs.
However, I installed these "Barker Manufacturing Company 24140 1.5"and 3" Auto-Drains" on my TT to assist me in draining the tanks.
The manual pull handles were positioned in a way as to cause me to bend in such a way as to cause me problems with my back and knees.
I love them. And if they should malfunction, it is easy enough to manully override them. Would definitely recommend them and would install them again if the need arose.
Dave H M
IL
Posted: 03/26/20 07:41am Link  |  Quote  |  Print  |  Notify Moderator
I still use the cable ones.
Here is something to ponder when messing with pesky cable valves that are covered by the under belly.
Go to amazon or anywhere and buy a quality valve with new cable attached. Don't pull the underbelly down, since you seem to know the location of the valve just cut a square hole with one of the four sides left uncut to act as a hinge. Replace the whole mechanism and button it back up with gorilla tape. My replacement valves and cables have been working fine for 8 years now. Just my two pennies.
