RV.Net Open Roads Forum: Class A Motorhomes: Chassis AC drain hose
 > Chassis AC drain hose
dmanharan
Posted: 03/24/20 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Hi ..I am new here.
I have a 2007 FleetWood Terra mounted on Workhorse Chassis and looking for a drain hose to fit on the bottom of the Evaporator.
I contacted Workhorse who said to contact FleetWood who said to contact DENSO.
The ac works great in all position of the vents.
My concern is that cold air is coming out of the vent..
Any suggestions will be appreciated.
Thanks.
Home Skillet
Pearland Texas
Posted: 03/24/20 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Measure the size of the drain.
Then you may be able to match up one of these.
LINK
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
garyemunson
Reno, Nevada
Posted: 03/25/20 04:09am Link  |  Quote  |  Print  |  Notify Moderator
Cold air is supposed to come out of the vent. Helps eject the condensate. I don't believe they have ever come with a hose like is often the case on cars. Usually an RV chassis provides a clear enough drop for the water right to the ground.
RLS7201
Posted: 03/25/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Denso HVAC parts.
Click on down loads and and click on service parts.
Item # 24
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
dmanharan
Posted: 03/25/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your quick response.
