RV.Net Open Roads Forum: Fifth-Wheels: Sandpaper 5th wheel
 > Sandpaper 5th wheel
rayroof10
chester
Posted: 03/25/20 12:46am Link  |  Quote  |  Print  |  Notify Moderator
I have a question about my roof top a.c. l have my camper parked and set up at a site with about 35 others. And when it really hot and everyoneIs running their AC some of the campers Air conditioners trips out that's because the wiring is old in the park what I was wondering they habit extra hours campsite beside me that no one is using is there any way I can hook up my rooftop air conditioner straight to that of the site Using a heavy duty extension cord
valhalla360
No paticular place.
Posted: 03/25/20 03:01am Link  |  Quote  |  Print  |  Notify Moderator
Look at getting a voltage booster.
Watts = Amp * Voltage
As the voltage drops the amps go up. Eventually, you are pulling too many amps.
The air/con will still see the low voltage even if you wire it into a nearby pedestal.
PS: I assume you've already shut down the other electrical draws (ie: your not trying to pop microwave popcorn with the air/con running)
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
rayroof10
chester
Posted: 03/25/20 04:06am Link  |  Quote  |  Print  |  Notify Moderator
No I,m not.but anywhere else we been Before we part it never had a problem S just that the amperage or Bowditch at that park is it big enough to Curie a lot of campers and now that it's part I'm just naden to know what I need to do so I can run my Air conditioner during the hottest days of summer
4x4ord
Alberta
Posted: 03/25/20 05:39am Link  |  Quote  |  Print  |  Notify Moderator
Would something like this work? You will want something rated for about 30 amps.
* This post was edited 03/25/20 05:45am by 4x4ord *
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Cummins12V98
on the road
Posted: 03/25/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I have owned this 50A AutoFormer since 2011, works well. I have done this type of install on two DRV's with same AF.
If it ever goes bad I simply would unplug and connect the cord caps.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Arizona
Posted: 03/25/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
I'd be willing to bet that when the voltage drops enough to start tripping A/C units, the =entire= park's voltage drops, so plugging in to an unused pedestal likely won't help you. I think I'd check the next pedestal over, and any other unused pedestals, when voltage starts dropping. Only solution I can think of is a voltage boost transformer, as has already been mentioned. IIRC, they give about a 10% voltage boost, so if voltage is below about 98v, they'd still only give you marginal voltage. From what I've read over the years, an A/C wants about 105v, minimum, to run without damage. Were it me, I'd be hammering the park owners to upgrade, or I'd move, if at all possible.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
garyp4951
TN
Posted: 03/25/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
What # grit is your sandpaper.lol
rayroof10
chester
Posted: 03/25/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry what do you mean what # grit is my sandpaper. And how does a boast transformer work and how and where is it installed
Cummins12V98
on the road
Posted: 03/25/20 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Read your thread title!
Always proof read before submitting.
Etstorm
Frankston,TX
Posted: 03/25/20 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Things are a little rough right now!
