RV.Net Open Roads Forum: Class A Motorhomes: 6 volt batteries in series
 > 6 volt batteries in series
2oldman
AZ
Posted: 03/25/20 10:34am Link  |  Quote  |  Print  |  Notify Moderator
dalefuji wrote:
Can I switch to 2@ 12 volt batteries without problems with the power inverter or do I have to change or upgrade power inverter.
You do really mean inverter, or converter? No changes to your CONverter, which charges your batteries.
ArchHoagland
Clovis, CA, USA
Posted: 03/25/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting... I never heard batteries called jars.
I learn something new on here everyday.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
2oldman
AZ
Posted: 03/25/20 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
ArchHoagland wrote:
Interesting... I never heard batteries called jars. .
Yeah, there's a few on here who do that. I guess that originated from the first batteries.. Leyden jars. Also, shorter word than batteries.
Wherever I happen to park
Posted: 03/25/20 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
Matt,
How about explosion/issues with 4x 6V for 12V?
One thing to think about.. When you take two 6 volt batteries and put 'em in series like this:
-{6v}+-{6v}+==== 12 volt
What you have is a SINGLE 12 volt battery.
You put two pair in a series/parallel
You still have one 12 volt battery (around 450 amp hours).
I run a six volt pair in parallel with 3 different size 12 volts.
I've never had a battery explosion (I'd like to run all one size on the 12 volts but. alas.. store was sold out)
But.. IF one, espically the smallest, shorts, an explosion is possible.. Now least you worry.. the "Exploison" is about as powerful as a bubble gum popping. but it scatters all the acid in the battery which is why you need to do a soda wash.
Home is where I park it.
theoldwizard1
SE MI
Posted: 03/25/20 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
The Trojan J150 is a 12 volt true deep cycle battery for you to consider. 150 AH
http://www.trojanbattery.com/pdf/datasheets/J150_Trojan_Data_Sheets.pdf
Check the price! $$$ OUCH !!
theoldwizard1
SE MI
Posted: 03/25/20 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
Most 6V GC batteries used in RVs are 230A giving you 12V at 230Ah. Most 12V RV batteries are about 80Ah giving you 160Ah. Marine deep cycle batteries are a compromise and not much better than starting batteries.
If you buy your batteries at Sams Club or Costco, a pair of GC2 golf cart batteries will cost less and as stated, give you more power.
theoldwizard1
SE MI
Posted: 03/25/20 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
There are boats and then there are boats. My trawler had 3x 8D batteries, large heavy puppies. Never had a problem but batteries do explode but not to often IFAIK.
Lead acid batteries explode when over charged/over discharged (welding/shorted) and/or the liquid level is low.
theoldwizard1
SE MI
Posted: 03/25/20 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
Not all batteries are alike.
12 volt batteries. most of these are MARINE/deep cycle or MARINE/rv Now Trolling batteries are True DEEP CYCLE.
IMHO, any battery that advertises Cold Cranking Amp (CCA) or Marine Cranking Amps (MCA) is NOT a true deep discharge battery.
Matt_Colie
Southeast Michigan
Posted: 03/26/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
Matt,
I have never seen or gotten paid to clean up after a bank of 6V that had problems.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
Matt_Colie
Southeast Michigan
Posted: 03/26/20 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Bumpyroad wrote:
for the last 60 years fisherpersons have used two 12 volt batteries in parallel to run their trolling motors. I have Never heard of this explosion. I certainly would not take this "fact?" into consideration on my setup.
bumpy
Bumpy,
I have seen one (and only one) explosion in a trolling motor bank of parallel 12V. That happened when the owner tried to use it to crank the big motor on his bass boat.
Trolling motor service is basicaly light duty and the related chargers are not all that powerful. That all works in your favor.
Matt
