RV.Net Open Roads Forum: Travel Trailers: How are your solar panels mounted?
 > How are your solar panels mounted?
Twistedlarch
Cottage Grove, OR.
Posted: 03/25/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
How do you all have your panels mounted on your roof? Does anyone have a set up that allows you to angle in any direction to maximize sun exposure?
Thanks
Brian
2oldman
AZ
Posted: 03/25/20 11:31am Link  |  Quote  |  Print  |  Notify Moderator
4 two-bolt brackets per panel. Nope, just two directions.
jdc1
Riverside, Ca
Posted: 03/25/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Who wants to climb up there to move it every hour? You'll end up wrecking your roof eventually (retired general contractor). You'll get 6 hours+ of great sunlight even in winter if they are mounted as they should be.
CA Traveler
The Western States
Posted: 03/25/20 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
I read that 7 times on the roof is the average for panel adjustment. Most just add one additional panel and they are good to go.
2014 Grand Cherokee Overland
Bob
Yosemite Sam1
Under the pines.
Posted: 03/25/20 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
That's the reason why I did not mount mine on the roof.
Besides, I want my campsite under trees and tucked in the forest -- I can move my panel and need not the RV.
Ed_Gee
Central Oregon coast - Winter in AZ
Posted: 03/25/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
My panels are mounted flat on roof .... mounting brackets fastened to roof with 3M double sided tape. Mount brackets have option to add tilt bar for the panels if I am parked for extended period.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
Kern County, CA
Posted: 03/25/20 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Four 2 bolt brackets for each of my three panels. Not interested in tilting...up and down a ladder repeatedly. Three panels sufficient so far. Will add a fourth someday. I wired for four panels. Hint - wire more than sufficiently.
pianotuna
Regina, SK, Canada
Posted: 03/25/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are riveted to aluminum angle. The angle is held to the roof by six screws per panel.
Regards, Don
Ivylog
Blairsville, GA and WPB, FL.
Posted: 03/25/20 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I took advantage of the raised side rails on my DP to tilt 7 of the 9 I installed.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
12thgenusa
Loveland, Colorado
Posted: 03/25/20 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are able to tilt in four directions. No running up and down. I just set them at the "optimum" angle for the latitude and month. I generally don't tilt if I'm going to be some place less than three days. It's more advantageous to tilt the further north you are. Some of us don't have the space to just add one more panel.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar,
Rogue MPT-3024, 440 AH GC2 bank, ProWatt 2000,100% LED lighting
