RV.Net Open Roads Forum: Class A Motorhomes: jacks up or down
 > jacks up or down
ggrotz
san mateo,ca
Posted: 03/25/20 11:39am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 samba class a.When I put it into storage is it better to put the jacks uo or down thank you.
jdc1
Rescue, Ca
Posted: 03/25/20 11:44am Link  |  Quote  |  Print  |  Notify Moderator
It doesn't matter....they are leveling and stabilizing jacks. You don't need either if you aren't using it.
SAR Tracker
Central Oregon
Posted: 03/25/20 11:55am Link  |  Quote  |  Print  |  Notify Moderator
If they are hydraulic cylinders (can you see a shiny shaft extended when they are lowered?) then they should be stored in the closed/retracted position. Otherwise, rust will form on the shaft, and when retracted after storage, will damage the hydraulic seals.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
Yosemite Sam1
Under the pines.
Posted: 03/25/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe needed down if storage is in specially high wind locations.
Found myself inside an RV with 50-70 mph wind and I have to put mine down even on a temporary stop.
doxiemom11
Yoakum Texas
Posted: 03/25/20 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Our hydraulic cylinders do not rust. We have been full-time since 2011 and sit from 4-6 months at any one time with the jacks down/extended. We have been within a mile of salt water and that didn't happen. This is not true. I would say, consult your owners manual or see if there is an answer on your manufacturers website.
Johno02
Lexington, TN USA
Posted: 03/25/20 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ours is stored in the drive with the jacks down to level it. We do spray the pistons with grease occasionally to help keep water off.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
ernie1
Sacramento,California,USA
Posted: 03/25/20 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have the Bigfoot levelers and the company says it is okay to store the jacks up or down since the shafts are stainless steel and don't rust. I always spray them well with a silicone spray as per manufacturer's recommendations.
Mojave, Kern County, CA
Posted: 03/25/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
“Found myself inside an RV with 50-70 mph wind and I have to put mine down even on a temporary stop.“
No need to put down a Class A’s jacks in 50-70 mph winds other than for your comfort.
Wherever I happen to park
Posted: 03/25/20 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
If they are leveling jacks::::: One expert Said lower 'em and in fact raise 'em a bit more than you need to take some of the load off the springs.
If they are stabilizing jacks. Your choice. Depends on if you plan to walk about inside the rig.
Home is where I park it.
dougrainer
Carrolton, Texas
Posted: 03/26/20 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Slides and Jacks when stored. NEVER extend Jacks for storage and never leave slide rooms extended in storage. WHY? Because IF they malfunction and will not retract, you are stuck until you get it fixed. There is NO REASON to extend jacks in storage. Even if fulltime, you need to cycle the jacks twice a month, Same for slide rooms. I get calls all the time from customers that have left Jacks or slide rooms extended in storage and they cannot get them to retract. Nothing I can do, until they get the RV in to me. Otherwise they have to call a mobile repair service. Doug
 > jacks up or down
