RV.Net Open Roads Forum: General RVing Issues: Propane Switch: Was Red, Now Green
 > Propane Switch: Was Red, Now Green
DallasSteve
Posted: 03/25/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2 propane tanks on my motorhome and there is a switch in the middle that directs which tank you want to use. I read the manual (really) and it said when one is empty the switch will change from green to red and start using propane from the other tank. I've been running the furnace a bit at night and so this morning I checked. Both tanks started out full on this new RV I bought. The switch had been on the right tank (for no particular reason). This morning the switch was red for the first time. I think this means the right tank is now empty and it is now using the left tank. I switched it to the left to see if it was green. It was green. Then I switched back to the right tank where it was red and now it shows green. I went back and forth several times (and again a few hours later) and now they are both showing green. So what does this mean? A bad switch? An almost empty tank? I now have the Coronavirus? I actually got an email from the Texas Parks Department today telling me that someone at Cedar Hill State Park tested positive for COVID-19 so they are closing the park. They wanted to tell me because I was there Sunday. I've got no signs yet. I think my broccoli will kill any virus.
rdhetrick
Posted: 03/25/20 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
My guess is that the temperature rise during the day caused enough of a pressure increase in the tank to push the indicator up to green. I'm sure it's empty though, so time to get it refilled.
Rob
2005/06 Mandalay 40E Full Time
2015 Jeep Grand Cherokee
Howie3
Red Deer, AB
Posted: 03/25/20 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
You could always unhook the right tank and lift it to see if it was indeed empty. I never knew for sure about how the indicators read for both tanks.
I'll keep my fingers crossed on your not getting coronavirus from the park. I'm sure the broccoli will kill it though. I read it on the internet.
Howie
PawPaw_n_Gram
On the Road Somewhere
Posted: 03/25/20 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Well, 82 yesterday on Lake Tawakoni. 52 this morning.
I've seen temp variations like that make the cutover switch go from empty to full and back several times in the past six years of full-timing.
I always take the 'empty tank' off the trailer and get it refilled. Some times it only will take 6.5 or 6.6 gallons in that situation, rather than 6.8 as is normal.
I've never replaced the switch.
When it shows empty, plan to fill it at the first opportunity. And 84 degrees today might make it flip flop again.
Full-Time 2014 - ????
“Not all who wander are lost.”
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
salem
Central Valley, Ca
Posted: 03/25/20 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Possibly the reason it stayed green when you switched it back to the empty tank is due to it having pressure in the lines. Close your left tank. With handle pointing toward right tank, turn a stove burner on. This will relieve the pressure. Your gauge should turn red.
jdc1
Riverside, Ca
Posted: 03/25/20 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Ding, ding, ding....winner!
opnspaces
San Diego Ca
Posted: 03/25/20 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
I'm with salem on this one since I've observed this many times. As said close the left tank and run a stove burner. once the pressure bleeds out of the line the gauge will go red.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
bucky
Raleigh metro
Posted: 03/26/20 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Make sure that the lever is in the left position before you unhook the right tank to go get it refilled. Or turn off the left tank if you don't need it for anything until you get back with the newly refilled right tank. I can't say all regulators act the same way but just to be sure.
2005 Cummins 2500 2WD LB quad cab pulling a 2014 Blue Ridge 3025RL
Wherever I happen to park
Posted: 03/26/20 06:06am Link  |  Quote  |  Print  |  Notify Moderator
The Red/Green is a pressure gauge. When you switched over the pressure rose. there may be a check valve to keep the pressure from "Bleeding" down into the empty tank.. So unless you draw propane off by some means it will continue to show GREEN till something turns on.
Recommendation: Refill the empty tank.
Home is where I park it.
Dave Pete
Wyoming
Posted: 03/26/20 06:29am Link  |  Quote  |  Print  |  Notify Moderator
That's right. If you closed both valves and reduced pressure in the line (open stove, re-close) then opened both valves with the selector on the right empty one you could probably duplicate the entire experience.
