RV.Net Open Roads Forum: Well we are almost full timers & the bunkhouse room
 > Well we are almost full timers & the bunkhouse room
Matt1221
Posted: 03/25/20 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Well we are almost full timers & the bunkhouse room with house doors.
We are in texas & that back room gets pretty hot even with todays high of only 87. I have a portable AC but I'm fairly certain the window exhaust attachements are all for square frame windows, which we have rounded corners.. What is the best method to tackle a window exhaust port for a portable ac in an rv? A quick search on amazon/ebay & google are slim pickens for ideas.
gbopp
The Keystone State
Posted: 03/26/20 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Temporarily, I would cut a piece of heavy cardboard to fit in the window and run the vent through the cardboard.
Did you check Youtube for DIY portable a/c vents?
GrandpaKip
Flat Rock
Posted: 03/26/20 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Or a piece of styrofoam insulation board.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Jebby14
Windsor Ontario
Posted: 03/26/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
cardboard to try form and fit then have it cut from aluminum?
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
bid_time
Michigan
Posted: 03/26/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
I used Plexiglass and cut it to fit both the tube and the window.
cavie
Posted: 03/26/20 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
I use a box fan in the doorway on my 32' rear BH.
