RV.Net Open Roads Forum: Class A Motorhomes: Unusual tire wear
 > Unusual tire wear
spotrot
Indian Rocks Beach, FL
Posted: 03/25/20 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
The outer treads on my steer tires have apparently worn to enough to expose a different rubber compound. I wondered if anyone else has experienced this. The rest of the tread is excellent.
The tires are 245/70R19.5 Bridgestone R250 and according to the charts have been over inflated if anything at 90 psi on a light front end (in spite of the relative heavy wear on the outer treads).
Bridgestone CS had no useful info, just said to take it to Larry, Curly and Mo at my local tire dealer for inspection.
Thanks
John
I'd post a photo if I knew how
rk911
Wheaton IL
Posted: 03/25/20 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
might be an alignment issue. hit any particularly bad potholes lately?
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Beverley&Ken
Tottenham,Ontario
Posted: 03/25/20 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds more like a front end alignment problems. Have it checked, realigned at a truck shop that specializes in alignment, frame and spring issues.
If you have the same tires all around the RV, it would be time to have them rotated.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
spotrot
Posted: 03/25/20 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies
Camber and toe are good
When the tires were new, we had to drive westward for 2 days with unrelenting 30 mph cross winds - that took a fair amount off the outer treads. Other than that trial, no suspension issues.
I just wanted to make sure that what I'm seeing is not a different rubber layer just above the cord. And wanted to know if there was a particular issue with those tires.
Executive
Posted: 03/25/20 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
IMO the tires should be inspected by a reliable tire shop. If they are 22.5 tires, I'd use a shop specializing in truck tires....we can't offer you advice on the safety of those tires without a visual inspection. They may be safe, but they just as well may be dangerous. Don't compromise the safety of yourself, your family and those who share the road with you....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
garyemunson
Reno, Nevada
Posted: 03/26/20 06:24am Link  |  Quote  |  Print  |  Notify Moderator
My experience over the years is that the F53 chassis RVs drive much better if the toe-in is set at the maximum positive value in the manual. Affected much less by wind/passing trucks. Much less steering corrections needed. The downside is I have always experienced outer edge tire wear when I have the shop make sure that is what the setting is. Have had a couple RVs in the past that when I got them required a lot of correction going down the road. When checked, one had zero toe-in, the other had been slightly negative. When the tech set them to the high end of the manual value, they drove far better. We always get around 50-55K miles out of rear tires, the fronts I'll change out at 40K due to outer edge wear. I'll swap some tire wear for more relaxed driving any day. I'm guessing your RV tracks like a railroad locomotive going down the road. This is, of course, assuming that the front end is tight and you keep everything properly greased. I'm a firm believer in chassis lubricating at every oil change. I don't think you could possibly wear out the front end on an F53 if you do that. The coach body would turn to dust first.
Belting 1313
Gresham Oregon
Posted: 03/26/20 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I agree with all that has been said it most likely is an alignment issue. However you did say something interesting about the front end being light. It is possible that if you are running to light on the front it will cause odd tire wear.
spotrot
Posted: 03/26/20 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Thank you to all who commented and I especially appreciate the info re toe on F53 RVs - that kind of info is only available from experienced RVers.
The actual stock weight on the front tires of this 30' RV is less than the any value on the weight/tire pressure chart for these 19.5 tires. I think the chart was wrong because the tread wear indicates wear would have been more even if the pressure was always 100 psi or more,
zigzagrv
Nazareth, PA
Posted: 03/26/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Generally speaking, over-inflation causes the center of the tire to wear and under-inflation the outside edges. The way to get the proper inflation is to weigh the axles, preferably the individual corners. This should get you in the ballpark of the proper tire pressures.
If both the inside and outside edges of the tire are worn, under-inflation is the problem. If just one edge is wearing, it is most likely an alignment problem.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
spotrot
Posted: 03/26/20 08:33am Link  |  Quote  |  Print  |  Notify Moderator
All accurate info. What perplexes me (and may be of use to others) is that I weighed each wheel, and then used the charts for air pressure for that size tire. In fact I actually increased the air pressure over what the charts recommended but the tires still wore much faster on the outer treads. My guess: the chart was wrong or this particular tire construction makes the outer tread wear down prematurely
 > Unusual tire wear
