RV.Net Open Roads Forum: Tech Issues: Would solar be effective in the midwest?
 > Would solar be effective in the midwest?
BFL13
Victoria, BC
Posted: 03/26/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Lead acid batteries can accept "full charge" well past 80% SOC
It is all about the "charging rate", which is the amps/AH of battery bank. At any charging voltage, the lower the charging rate, the higher the SOC before amps taper at the end of Bulk and VV.
Solar often has lower max amps wrt the size of the battery bank, so that makes for a low charging rate, and so the end of Bulk in the 90s for SOC.
I don't understand what possible settings you can have on a solar controller that would alter that. The battery type settings usually only change the high voltage set point, which can change the amps being accepted. Higher voltage can mean more amps at any given SOC if the solar can provide more amps. Not going to change the charging rate very much between 14.4 and 14.8 eg.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
2oldman
AZ
Posted: 03/26/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
I don't understand what possible settings you can have on a solar controller that would alter that..
You talking to me?
Boon Docker
Posted: 03/26/20 10:59am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
Solar is just a way to extend the time between generator/charger recharging.
I highly doubt that statement.
I use just solar to charge my GC2's. I have never used a generator to charge my 8 year old batteries and they are still going strong. I boondock 99% of the time.
BFL13
Victoria, BC
Posted: 03/26/20 11:03am Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
You talking to me?
No, the guy who thinks the controller sets the battery acceptance rate instead of the battery doing that for itself.
Seattle Steve
Tucson
Posted: 03/26/20 11:08am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
2oldman wrote:
You talking to me?
The fact that you don't understand only means that you don't understand; not that you have a valid point. [emoticon]
BFL13
Victoria, BC
Posted: 03/26/20 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Right, so your time with solar between gen/charger charging is long enough so you don't have to use the gen before getting to shore power again.
That can be all summer or for several days in winter, whatever the scenario is. Including how many batteries in the bank, and your daily usage.
BFL13
Victoria, BC
Posted: 03/26/20 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Seattle Steve wrote:
BFL13 wrote:
2oldman wrote:
You talking to me?
You are invited to explain or link to an explanation of what you mean about solar controllers so the rest of us can try to understand it.
Otherwise you are saying something against what is well known about battery acceptance rates and charging profiles.
Boon Docker
Posted: 03/26/20 11:33am Link  |  Quote  |  Print  |  Notify Moderator
The last time my batteries were on shore power was 4 summers ago for one week. That is a pretty long extended time. [emoticon]
BFL13
Victoria, BC
Posted: 03/26/20 11:50am Link  |  Quote  |  Print  |  Notify Moderator
I got in three days early last week where I would have had to use the gen and charger every day, but got in some solar so didn't have to use the gen until the second day. So solar extended my time between gen charging by a day. Or by 100% if you want to make that look good.
A couple days after getting home they closed the provincial parks for camping because of the Covid-19 thing, so am stuck on the computer at home getting in trouble. They are letting the local dog-walkers in the park (Rathtrevor) all day same as usual, so I don't see how camping overnight can spread the virus particularly. Phooey.
Mojave, Kern County, CA
Getting many RVers to read the basics of battery charging is nearly impossible, Steve. They would rather complain than learn.
