RV.Net Open Roads Forum: Tech Issues: hydraulic cylinders
 > hydraulic cylinders
dalej
texas
Posted: 03/26/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
My trailer has a large hydraulic cylinder used to raise and lower front of trailer. I was wondering if I should take the pressure off of it when in storage.
2005 Chevy HD2500, ext cab, 4x4, 8.1, allison,lwb,srw, 265 75 16's, timbrens
Cummins12V98
on the road
Posted: 03/26/20 07:35am Link  |  Quote  |  Print  |  Notify Moderator
IMHO not needed.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
BB_TX
McKinney, Texas
Posted: 03/26/20 08:09am Link  |  Quote  |  Print  |  Notify Moderator
MHs and many 5ers have hydraulic cylinder controlled leveling legs that remain under pressure for long periods of time, That is what they are designed to do.
12th Man Fan
Flower Mound , Texas
Posted: 03/26/20 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Absolutely not necessary.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 03/26/20 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
If a ram's chromed shaft is exposed Mopar SYNTHETIC automatic transmission fluid is positively superb as a rust inhibitor that will not endanger seals.
ScottG
Bothell Wa.
Posted: 03/26/20 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
AKA, ATF +4. [emoticon]
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
DFord
Near St Louis, MO
Posted: 03/26/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
The rams on the levelers for my MH are chrome plated. They can pit if exposed to rain. Grease them up heavily if they're exposed. The pits rip the seals when they move past them.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
cavie
Posted: 03/26/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
It will be fine holding it up. Are you sure it's not 12 electric?? I have not heard of HD on the front of a trailer. But then I am old and I don't sleep at Holiday Inns. LOL
dalej
texas
Posted: 03/27/20 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tip on greasing the exposed ram.
Cummins12V98
on the road
Posted: 03/27/20 08:49am Link  |  Quote  |  Print  |  Notify Moderator
The exposed Ram only needs to be cleaned off occasionally and prior to retracting with Silicone Spray.
