Kxracer704
NE Pennsylvania
Hello all,
My girlfriend and I got a classic 1977 Sunline truck camper (11 FKS Model) for a very reasonable price.....free. We started the large task of fully rebuilding this beast from the ground up. We have posted this build on the Sunline Coach Owner's Club Forum (for those who are also on that forum).
See images attached for the how the camper looked when we picked it up. Also check out my***Link Removed*** youtube channel (search for kxracer704 and click on the truck camper playlist) for video updates on this entire build.
![[image]](https://i.postimg.cc/J04pgrvW/IMG-3899-cropped.jpg)
![[image]](https://i.postimg.cc/25h9LXhg/IMG-3898-cropped.jpg)
![[image]](https://i.postimg.cc/qMNLC5dQ/IMG-3901-cropped.jpg)
Thanks!
Jay & Jenette
ScottG
Bothell Wa.
I did a project like that years ago. We had a blast in that camper and hauled it all over the western side of the country. We still talk about how nice it was inside with its wood paneling. It was warm feeling, homey and I wish we could still get them that way.
Good luck and we look forward to seeing your progress.
Scott
Kayteg1
California > Nevada
I always admire people taking hobbies and now is better time than ever to do projects at home.
Still the "free" can be interpret different ways in such situation.
The "seller" would have to spend nice money to have the camper hauled away.
No jacks? PM me if you need them.
Death Valley NP
If you want a project, you have one! If you want to go camping in the next two years+, buy another TC.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
AnEv942
CA
Enjoyment, other than just the 'doing', be a ways off. Good luck.
I'll be following. Curious how you got the camper up into the truck, that must have been interesting.
Our camper projects page
Kxracer704
NE Pennsylvania
For all following, here is the latest video... The Disassembly Begins - Truck Camper Build Part 5
last
edited 04/28/20 08:43am by an administrator/moderator *
View edit history
Kayteg1
California > Nevada
You are young and enthusiastic.
When you can't do much about 1st, work on being the 2nd all the time.
Such long projects get boring, get annoying, get frustrating, so spend time to keep it fun, or you will end as 99% of them unfinished.
When something stops you in your work - don't force solution the same day. Go home, have a beverage and think it over when you cool down.
Now some technical tips.
-don't put fiberglass back. It is worthless. Styrofoam or better urethane board have several times higher R-values.
-even siding come off, there is less dryrot that I would expect. So before you start restoration, make sure you level the floor on support. This way when you build it up, you can take construction level and make sure it is square
-glue for aluminium siding is crucial. In the past most RV manufacturers used corrosive glue and RVs had siding corroded from inside out.
-buy rolls of butyl tape and put lot of it under each joint.
I had Lance, where PO redid all the trim with butyl tape and when the "droplets" coming out look ugly, it prevent water leaks.
HAVE FUN and stay healthy.
Kxracer704
NE Pennsylvania
For all following, here is the latest video... We Have Walls - Truck Camper Build Part 6
GeoBoy
Bennington
KC, great job. Stay at it.
Kayteg1
California > Nevada
What screws are you using?
Heat-treated screw snap off with any movement and TC do have lot of movement.
You also need diagonal frame pieces on front wall for load carrying.
