RV.Net Open Roads Forum: Tech Issues: 12V heater run straight from solar panel
 > 12V heater run straight from solar panel
DarkSkySeeker
Freestone, California
Posted: 03/26/20 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Is there a heater product that can run off the 12V that comes directly off my portable solar panel? This would have to be something that can handle unregulated power that might peak up during bright sun and drop very low when a cloud passes by.
There is something special about camping in an RV.
agesilaus
North Florida
Posted: 03/26/20 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Even small 120 VAC heaters are 1200 to 1500 watts, that's a lot more than most peoples solar can put out. Heating is energetically expensive as is cooling aka air conditioning. But here are what is offered on Amazon
Be careful some are deceptive, the one 'universal heater' for example uses hot water from the engine block and the 12V is to run the blower motor.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Kern County, CA
Posted: 03/26/20 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Never encountered a heater that would run solely from solar.
DarkSkySeeker
Posted: 03/26/20 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
Even small 120 VAC heaters are 1200 to 1500 watts...
Thanks. Yeah, I was imagining a big resistor with a heat sink around it that would run passively. Perhaps I will find that.
Ed_Gee
Central Oregon coast - Winter in AZ
Posted: 03/26/20 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe something like this would work for you ....
12 Volt heat lamp
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
agesilaus
North Florida
That's what these electric heaters are. Resistor: NiChrome wire coil
Heat Sink: The surrounding air
The problem is that it takes many Joules to heat up that air and get ahead of heat losses thru the walls, air leaks and such. You can't sneak around the Laws of Thermodynamics.
DrewE
Vermont
Posted: 03/26/20 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
A big resistor that can dissipate a lot of power at 12V, sufficient to be a useful heater, is also a low-valued resistor, on the order of one ohm (approximately 150 watts). Making your own with resistance wire would probably be easier and less expensive than finding and affording a commercially produced resistor, marketed as such. Having a few coils wired in parallel is probably a good idea, too.
I'd think, for heating with solar power, that a solar water heater (as in a black pipe in a reflective trough or something similar) and a radiator of some sort would be more efficient and effective overall. The cost would probably be lower, too.
DarkSkySeeker
Posted: 03/26/20 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed. My basic motivations are like this: I have these solar panels and what if I used them to generate ~500W continuously? And to avoid the complexity of a water heater based system, I wanted to be able to attach the 1 ohm resister(s) to create passive and unregulated heat.
DarkSkySeeker
Posted: 03/26/20 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
What if I bought 5 of these, wired them in parallel, and mounted them on a board?
PRODUCT LINK
Flute Man
Payson, Arizona
Posted: 03/26/20 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 12 V 300 W heater in my rally compartment. It draws 25 A so figure yours accordingly.
Electric heaters have a very simple formula.
Watts Divided by volts equals amps.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
