RV.Net Open Roads Forum: Tech Issues: 12V heater run straight from solar panel
 > 12V heater run straight from solar panel
DarkSkySeeker
Freestone, California
Posted: 03/26/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Flute Man wrote:
I have a 12 V 300 W heater in my rally compartment. It draws 25 A so figure yours accordingly.
Electric heaters have a very simple formula.
Watts Divided by volts equals amps.
Did you buy it online? If so, could you share the link?
There is something special about camping in an RV.
Boon Docker
Posted: 03/26/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of 12v heaters on Amazon and Ebay.
Those 12v heaters are real power hogs. You would need a minimum 400 watts of solar to run a 300 watt heater. Which would put out very little heat in a large space.
time2roll
Posted: 03/26/20 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
You will be lucky to keep the 12v battery charged and burn propane running the furnace.
675w Solar pictures back up
Mojave, Kern County, CA
Posted: 03/26/20 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
25 amps? That’ll drain a battery. Or require five 100 solar watt panels producing at almost max.
DrewE
Vermont
Posted: 03/26/20 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
DarkSkySeeker wrote:
What if I bought 5 of these, wired them in parallel, and mounted them on a board?
PRODUCT LINK
At 12V, Ohm's law says that 1.2A would flow through each one, which means a dissipation of a bit under 15W each. Total wattage would be around 150W. To get 50W power dissipation, the applied voltage would have to be a bit over 22V.
According to the resistor data sheet, with no heat sink (i.e. mounted on a board), rated dissipation is 14W. To dissipate 50W each you must have a heat sink to keep their temperature reasonable. In either case they ought to be mounted on something that can take the heat; a wooden board would not be the wisest choice in my estimation.
$35 seems like a lot of money to spend for the anemic results you'd tend to get.
2oldman
AZ
Posted: 03/26/20 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a heater product that can run off the 12V that comes directly off my portable solar panel? .
One panel? You'd be lucky to heat an ant farm.
wopachop
lb
Posted: 03/26/20 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Some people use little 12v automotive bulbs to drain lipo batteries used for RC toys. One guy had quite a few on a board and said it put out a lot of heat.
I think what you propose will work to some degree. Maybe you can set a chair over your heat device. Like when someone puts a few campfire coals under a chair.
Flute Man
Payson, Arizona
Posted: 03/26/20 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
It came with my motorHome. Sorry
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
DarkSkySeeker
Posted: 03/26/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
My idea is to run the heater directly from stand-alone solar panel(s), not via the RV batts.
pnichols
The Other California
Posted: 03/26/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a heater product that can run off the 12V that comes directly off my portable solar panel? This would have to be something that can handle unregulated power that might peak up during bright sun and drop very low when a cloud passes by.
You might want to locate and buy one or more of these 120V 155 watt "personal heaters" that can keep one person per heater toasty if it's close to them and aimed right at them.
It has 3 settings - one fan-only setting for cooling and low and high heat settings. It consumes about 155 watts on it's high heat setting. We use a couple of them at home to warm us when sitting so we don't need to have the house furnace set so high. On RV trips I take both of them along for emergency heat boosting in specific areas of the coach when on hookups.
I have run one all night off a 300 watt pure sine wave inverter - fed by one Group 31 12V AGM battery - to heat the interior of my truck when sleeping in it overnight at a remote campsite. The two I have are several years old and have been super reliable.
https://www.ebay.com/p/1524623641?iid=274188423300
Phil, 2005 E450 Itasca Spirit 24V
