Kennyg
Green bay, Wi 54303
one day it was working the next day it was not. Checked fuse and its OK. Then went to switch which is controlled by cover; it seems alright. Fan is approx. 16 yrs old. Need suggestions. Thanks in advance for your input.
Kennyg
Death Valley NP
Sixteen years of service is great! Time for a new one.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Two Hands
California's Central Coast
I wish mine was quiet.
rrupert
NW PA
Check to see if there is any power in the circuit.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
gbopp
The Keystone State
If it's not working it will definitely be quiet. I agree with rrupert, make sure you have power going to the fan before you do anything.
Ron3rd
Upland, CA USA
Check for power AT the fan motor with the switch on. If you have power at the motor and no go, the motor died
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
enblethen
Moses Lake, WA
I would start at the switch and check for power.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
pinesman
virginia
Mine has a thermostat. If your has one, is it set right?
bob_nestor
murphy
Kennyg wrote: one day it was working the next day it was not. Checked fuse and its OK. Then went to switch which is controlled by cover; it seems alright. Fan is approx. 16 yrs old. Need suggestions. Thanks in advance for your input.
How did you verify the cover switch? Did you make sure the plunger moves freely up and down and also test the continuity with the plunger in both and up and down position? Typically the plunger gets stuck in the down (off) position so when the cover is raised the switch is still open circuit so the fan doesn't run.
ScottG
Bothell Wa.
You need to use a volt meter and follow the power.
If the motor is bad, you can get a replacement but it wont be as quiet as the original.
