RV.Net Open Roads Forum: Class A Motorhomes: Access to Grey Water Holding Tank
 > Access to Grey Water Holding Tank
KevinandHarvey
Canada
Posted: 03/26/20 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, We own a 2002 Winnebago Suncruiser Class A. Have an issue with a leaking from the grey water tank. Water leaks over the frame, undercarriage of the rig. How can I access this tank? K
IB853347201
Eastern Ontario
Posted: 03/26/20 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Go to http://www.winnebagoind.com/diagram/Plumbing.htm
Select your year and model.
Lots of other specs and parts info available from Winnebago.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
Executive
Posted: 03/26/20 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
Winnebago Plumbing Diagrams...Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
KevinandHarvey
Canada
Posted: 03/26/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you! Dennis looking at this diagram, the grey water tank is located closer to the middle of the rig. It is unclear to me how to get access. Worst case is there access from inside under the floor?
way2roll
Wilmington NC
Posted: 03/27/20 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried crawling under to see if it's a leak on the tank itself, or a connection? A camera scope can be had on Amazon for about $20, and are great for scoping out leaks etc that are otherwise physically hard to get to. They work with your smart phone.
KevinandHarvey
Canada
Posted: 03/27/20 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I have been under the rig. The tank is not visible or “mounted under”. Seems to be installed , sandwiched between the main floor and subfloor. Crazy. Can’t find any access.
IB853347201
Eastern Ontario
Posted: 03/27/20 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Why don't you call Winnebago service? They are very helpful.
MountainAir05
New Mexico
Posted: 03/27/20 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Not your RV, but when we had this I was able to find it and see from the sewage connection compartment door. I was able to find it and took a while to figure out how to reach it. Not easy but did get the bad connection cut out and put back together with out so many joints. Straight runs then cut as needed to get it all back to a working condition.
way2roll
Wilmington NC
Posted: 03/27/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Going to assume you know it's the grey by the levels going down on that specific tank? What about the blade/gate valves in the wet bay? Also can you see any connections in the wet bay?
KevinandHarvey
Canada
Posted: 03/27/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hey gang! Found the issue. Pulled up the whole outdoor shower assembly and discovered that the Grey Drain Pipe joint had separated! Three minutes later it was fixed. I did call Winnebago Tech and they were great however still no solution to how to access the rest of the tank. So all fixed. Thank You all for your help!!!!
Harvey
