RV.Net Open Roads Forum: No 12V power to prewired back up camera
 > No 12V power to prewired back up camera
Snomas
Sedona, AZ
Posted: 03/26/20 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
I went to install a backup camera to my Forest River flagstaff TT that is only 10 months old. I found thet there wasn't any 12V power to the preinstalled/wired furion bracket. I checked every where and couldn't get power. I didn't check the fuse's I will tomorrow. Is there a switch or or could it be something else. I think it should be hot as soon as the battery is turned on.
2018 F150 Lariat Crew Cab, 5.0 L V8, RWD.
2019 Flagstaff micro mini 21DS
Anderson WDH
afidel
Cleveland
Posted: 03/26/20 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
It might be a backup only setup where there's only power from the 7 way during reversing. I know there are two models from Furion, a during monitor and a backup camera, not sure if the wiring is actually different between the two.
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
Acampingwewillgo
Posted: 03/26/20 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
If it's like my friends trailer, that camera only works when you are hooked up to truck and your parking lights are on( your lights on). It only gets power then.
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund, Senior Cavalier Rosie and Potter
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie and Mollie, Elvis Love You!
Rally's and get togethers-Lots
Bobbo
Wherever I park
Posted: 03/26/20 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
On my trailer the marker lights have to be on. On the 7 way plug, jumper the 12v+ pin and the tail lights pin together. That should power the camera for testing purposes.
Bobbo and Lin
Walaby
Georgia
Posted: 03/26/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Mine too.. Marker lights on powers the camera.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Snomas
Sedona, AZ
Posted: 03/27/20 03:49am Link  |  Quote  |  Print  |  Notify Moderator
Thx. I’ll try that,
opnspaces
San Diego Ca
Posted: 03/27/20 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Definitely try putting it in reverse to check power. I just installed a backup camera last week and the instructions specifically said to pull power off the reverse lights..
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
tdiller
usa
Posted: 03/27/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
The camera runs off the marker lights. In many newer vehicles with automatic lights you will have to manually turn on the running lights which will power the camera.
Snomas
Sedona, AZ
Posted: 03/27/20 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
I did try the Marker lights today and found they powered the prewired fusion backup camera. it was an easy install. Thanks for all the info guys! I owned a DP for 14 years and always learned how to maintain my Rv thru forums like this.
Bobbo
Wherever I park
Posted: 03/27/20 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
He has a TT, there is no reverse on it. (He found out the marker lights was the magic bullet.)
