RV.Net Open Roads Forum: Water pump warning... a little long but may be worth it
 > Water pump warning... a little long but may be worth it
dockmasterdave
florida
Posted: 03/30/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Just a heads up to hopefully save someone from this problem.
I have a Gulfstream Amerilite, kept at home and plugged in.
Yesterday I noticed water dripping from the front corner and figured it was A/C runoff. I looked closer and couldn't see it dripping from the gutter, or running down the body. Opened my front storage compartment and the floor was wet with some standing water.
Checked the roof and no water puddling from A/C. Opened the a/c cover and found almost no condensation at all. No water dripping inside, no wet ceiling or walls.
Then I realized, the only other thing with water, in that area, was my fresh water tank.
Took the bed apart to get to it and found if I touched the pump outlet connection, water sprayed out.
It is a flojet 03526. It has quick connections at each side. Apparently one of the o rings is bad. I guess whenever using the pump it must have leaked slowly and recently got worse.
Glad I was home to find it before it caused any damage.
If you have a pump with these quick connects, check them carefully. New quick connectors with O rings are only about $10 a pair with shipping.
2014 F 150 ecoboost
2010 F 150 4.6L
2007 ranger
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
Bishop area, California
Posted: 03/30/20 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Good suggestion.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Old-Biscuit
Verde Valley
Posted: 03/30/20 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Never understood 'quick connections' on an RV water pump.
Just have many times do you need to remove/replace one that it needs quick disconnects
US NAVY------USS Decatur DDG31
Hondavalk
Toledo
Posted: 03/30/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Posted: 03/30/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
It’s cheaper and faster to install during the build.
Ductape
On the Road
Posted: 03/31/20 05:48am Link  |  Quote  |  Print  |  Notify Moderator
That’s how you incentivize people to buy the same brand of pump again to avoid changing the connections.
49 States, 6 Provinces, 2 Territories...
joelc
Cedar Point, NC
Posted: 03/31/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Did you have it connected to water. Sometimes the back flow in the pump does not work and if connected to shore water you will get water in the tank which can overflow. I resolved this problem by putting a valve before the pump, so if I use shore water I shut it off. Using the pump, I turn it on. I know this was not your issue, but thought I would give you a heads up.
ScottG
Bothell Wa.
Posted: 03/31/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I do it once a year to get water out. If it wasn't there I would just run it dry.
B.O. Plenty
Minnesota
Posted: 03/31/20 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Go to a hardware store or auto parts store and get the same O-rings for about 10 cents each. Just bring in an ols one and match it up. Wouldn't hurt to get a couple spares.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
