RV.Net Open Roads Forum: Resealing DRV A/C Dometic Penguin II Unit On Roof
 > Resealing DRV A/C Dometic Penguin II Unit On Roof
Cummins12V98
on the road
Posted: 04/05/20 10:04am Link  |  Quote  |  Print  |  Notify Moderator
I agree people should check tightness of lag bolts. I have owned 2 DRV's over 9 years with zero leaking. I am on DRV Forums with no leaks mentioned.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
dmorse68
Palm Desert
Posted: 04/05/20 11:59am Link  |  Quote  |  Print  |  Notify Moderator
pcm1959 wrote:
Those lag bolts that hold a/c unit on to the roof on many of the new RVs with no visible means of attachment on the inside are a huge source of possible water as they are outside the a/c seal and/or shroud. Be SURE they are properly sealed.
Many a/c units are leaking into the roof on these types of a/c units unknow to the owner since it is not likely to show up on the inside due to the insulation and ceiling panel particularly if a vinyl/padded ceiling.
The only way I discovered I had water intrusion was, I took the bedroom’s fantastic fan inner shroud trim piece off so that I could place a mouse trap up in the insulation cavity, and saw the roof plywood dark and wet.
-David
DRV 36RSSB3
pcm1959
home
Posted: 04/05/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
There ya go! Trust me, there are many, many others with the same situation and don't know it.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
Cummins12V98
on the road
Posted: 04/05/20 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
This is why the lag bolts should be checked.
Retired JSO
Northeast Florida
Posted: 04/05/20 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
There are 3 units on my fifth wheel. After a heavy rain,I discovered a small drip of water at the most rear register actually behind where the a/c is mounted. Thought at first it was condensation. After another heavy rain, drip drip. I then torqued all the lag bolts on all 3 to 50” pounds which has stopped any visible leak.
Cummins12V98
on the road
Posted: 04/06/20 11:18am Link  |  Quote  |  Print  |  Notify Moderator
"I then torqued all the lag bolts on all 3 to 50” pounds"
That's an interesting torque. Reality that's slightly above 4'# TQ.
TXiceman
Full Time RVer
Posted: 04/06/20 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
You only want to compress the gasket, not crush it.
Ken
Amateur Radio Operator.
