RV.Net Open Roads Forum: Fifth-Wheels: cabinet door coming apart
 > cabinet door coming apart
Cummins12V98
on the road
Posted: 04/05/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
larry barnhart wrote:
Cummins12V98 wrote:
That is simply a disgusting product !
because it gets on your fingers? does mine but have used it many times.
chevman
Personally, quality wood glue for me like Titebond. That mitre will look just like that for years to come.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Edd505
Elephant Butte, NM
Posted: 04/05/20 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
looks like a simple glue job.
chevman
Glue plus clamps of some sort to pull it tight and hold it while the glue sets: Same principal here he fixes a Table but the idea is the same
About 8:10 he's doing a cabinet door. I have a bunch of wood clamps in my shop but this is like the ones I use the most.
Clamp
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
rtreptow7
Central, WI
Posted: 04/09/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Just an update. Brought the door in the house last weekend. Was going to go borrow some pipe clamps from my father in law. Grabbed the door to show him and the floating panel now seemed loose and I could easily squeeze the frame back together by hand. Last weekend I couldn't get it to come together no matter how hard I pushed on it. The door did sit in my wood furnace room over the past week. It gets pretty warm and dry in there. So I'm guessing the humidity evaporated out of the wood? Will try to glue and clamp it back together and see what happens when it returns to the elements.
2018 GMC Sierra Denali 2500HD Crew Cab 6.0L 4.10
2019 KZ Durango 1500 286BHD fifth wheel
2010 GMC Sierra 2500HD Crew CAb 6.0L 3.73 REPLACED
2004 Chevy 2500HD Exteneded Cab 6.0L 4.10 gears REPLACED
2004 KZ Frontier 2453P-F fifth wheel-REPLACED
laknox
Arizona
Posted: 04/10/20 10:01am Link  |  Quote  |  Print  |  Notify Moderator
As one of the others said, you may want to disassemble the door and sand the center panel a bit, to give it a bit more space to "float".
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
rtreptow7
Central, WI
Posted: 04/10/20 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Lyle
I'd like to try and dissassemble but the thing is nailed or stapled together with tiny little nails or pins too. Not sure how to get those out without ruining the door finish. I'm wondering if the glue will be strong enough to hold the door frame together? I can see how the expansion ripped the pins right through the wood.
BarneyS
S.E. Lower Michigan
Posted: 04/10/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
From my experience, if you use good wood glue and clamp well the door will break somewhere else but not at the joint you glued together.
Barney
Not towing now.
blofgren
Surrey, B.C.
Posted: 04/10/20 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it is humidity that causes the wood to swell. I had the same issue on a cabinet door in my fiver when I had an RV cover on it in my back yard over the winter a few years ago. I too could not push the joint back together, and took it to a friend of mine who is a finish carpenter. He managed to put it back together and glue it, and it is good to this day.
Since then, the fiver has been in indoor storage every winter and there have been no further humidity issues.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
rhagfo
Portland, OR
Posted: 04/10/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
rtreptow7 wrote:
Lyle
I would glue and staple it back together, I carry an air powered Brad driver and stapler in our 5er for repairs.
