RV.Net Open Roads Forum: Truck Campers: Carrying a Honda 2000i inside generator compartment
 > Carrying a Honda 2000i inside generator compartment
welsteach
AK
Posted: 04/04/20 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/MORryde-SP60-041-Sliding-Battery-Tray/dp/B007HRQBRU
Thinking about using this tray to put our Honda on. It would make it so that I could pull out the tray, plug in the genny and go. It is a bear for me to carry from backseat to ground (physical disabilities and female upper body combined). Thoughts? Rated for 250#.
Was thinking I would put a thin rubber pad on bottom to absorb noise and keep genny from “walking” in the tray. It would pull out from generator compartment and exhaust away from camper, because of orientation in tray. Would need to take care mounting solidly because stress would be on mounts. Anything else I am missing?
Oh, mounting in Bigfoot 2500 10.6
Bishop area, California
Posted: 04/04/20 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
“and exhaust away from camper,“ Depending on the wind or even a light breeze.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
jimh425
Western MT
Posted: 04/04/20 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Have you considered a lockable front hitch mount? I would.
ScottG
Bothell Wa.
Posted: 04/04/20 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Seems like a great idea. Personally, I would prefer it in the gen compartment and out of view when not being used.
JimK-NY
NY
Posted: 04/04/20 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a generator compartment, why are you storing the generator on the back seat of your truck? Is your compartment already wired for a generator? Mine is. It also has two doors which allow the generator to run while in the compartment.
Downunda
Melbourne Australia
Posted: 04/05/20 05:38am Link  |  Quote  |  Print  |  Notify Moderator
My Australian built Jayco class C has a small generator compartment just big enough for a Honda 2kva or similar, it has an inbuilt sliding tray that the genny sits on. To use it I slide the genny tray out and plug a short lead into my mains input and it works great (with the tray slide out of course). Just what you were thinking of doing.
Just make sure that you ventilate the compartment so that any fumes can disperse when the door is closed.
To secure the genny when traveling I have it tied to the slide out tray with a strap.
srschang
Western NY
Posted: 04/05/20 06:29am Link  |  Quote  |  Print  |  Notify Moderator
My new Northstar came with a compartment for a Honda Generator with that same slide-out tray. It also has a plug in the compartment and propane plumbed to the compartment if I wanted to convert the generator to propane.
2020 Ram 3500 SRW Crewcab Longbed Cummins, 2019 Northstar 12 STC
Kayteg1
California > Nevada
Posted: 04/05/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for front hitch mount.
I have my Honda 3000 on front and it works like a charm, not to mention helps quite a bit with shifting the weight on front axle.
Posted: 04/05/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a good idea, probably. It's designed to carry generators, but I'd make sure it's designed to "run" generators on. I'd ask the question to moryde. If it won't vibrate apart if used in this manner
crosscheck
Coldstream, BC
Posted: 04/05/20 11:03am Link  |  Quote  |  Print  |  Notify Moderator
This is the set up I think you are looking at including security cable. The Citation TC before this one had no solar and like you, only place to store genny was on the floor behind driver. Big pain to move. In this Outfitter,we used the genny maybe only 3 times in 5 years because we ended up adding 330W solar plus 4 AGM 6V batteries under the dinette and we dry camped most of the time.
Dave
2016 F350 Diesel 4X4 CC SRW SB,
2016 Creekside 23RKS, 490W solar, 2000W Xantrex Freedom 2012 inverter, 4 6V GC-2 (450AH)
2006 F350 CC 4X4 sold
2011 Outfitter 9.5' sold
Some Of Our Fun:http://daveincoldstream.blogspot.ca/
