RV.Net Open Roads Forum: Tow Vehicles: Another Reason To Not Have Airbags
Search only in Tow Vehicles
 > Another Reason To Not Have Airbags
Page of 5
SweetLou
La Quinta, CA USA
Posted: 04/05/20 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I know this has been discussed to nauseum, but I am currently towing my cargo trailer that is combined weight of about 7K LBS, and some stuff in the bed of the truck and of course fuel and two bodies. I have a slow leak in the air system which after a day of traveling, it squats the truck and puts more weight on the front of the tandem trailer wheels. The truck handles the squat fine with a dually, but it causes for concern. I just add air and go at this point. Timbrens won't do this and I will be dumping the air system depending on what I find, and switching back at some point. Hopefully its just a small hole in the air line.
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
Devocamper
West Haven CT
Posted: 04/05/20 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Sumo springs work well for us , no air lines and ours are fully disengaged when there is no load in the truck also fairly easy install as well .
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
BobsYourUncle
Calgary Alberta Canada
Posted: 04/05/20 07:29am Link  |  Quote  |  Print  |  Notify Moderator
My air bag had a lot of excessive air, way too much in fact.
Enough to float 100 heavily laden trucks down the road.
But the problem went away after I divorced her....
[emoticon]
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
deltabravo
Spokane, WA
Posted: 04/05/20 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you need a weight distribution hitch.
2018 Timberridge 24RLS (bought pre-owned 3/12/20)
valhalla360
No paticular place.
Posted: 04/05/20 09:06am Link  |  Quote  |  Print  |  Notify Moderator
What's the tongue weight on that trailer?
I wouldn't expect a 7k trailer to cause significant squat on a dually.
As someone else mentioned, a WDH might make sense if it's inducing that much squat.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
blt2ski
Kirkland, Wa
Posted: 04/05/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Might also be how the load is spread in the bed.
IF OP is relying on air bags to hold the load, not springs per say, then yes, this will happen, not matter what is going on.
I barely pull of 200-300 lbs off the FA of my older now gone 3500's with 8500 lb RA's with a 1500 lb hitch load, from a 12K total trailer. A 7K with even 1000 lbs should not be pulling but 100-200 lbs off the FA, and not causing issues. I usually found it took at least 400, if not 500 or more lbs off the FA to cause steering issues with said 8 lug trucks.
Marty
Check RV.Net Blogs at: blog.rv.net
carringb
Corvallis, OR
Posted: 04/05/20 10:15am Link  |  Quote  |  Print  |  Notify Moderator
X2 on Sumo's. They simply ride better than Timbrens. T's cause rebound. Sumo's dampen it.
And yes airbags are a PITA unless you have onboard air.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
IdaD
Idaho
Posted: 04/05/20 10:16am Link  |  Quote  |  Print  |  Notify Moderator
I've been really happy with the Timbrens on my truck. No messing with them and they give me a nice stable ride when loaded up with the fifth wheel and etc.
2015 Cummins Ram 4wd CC/SB
Cummins12V98
on the road
Posted: 04/05/20 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Lou, why in the HE!! do you need air bags on a modern DRW RAM with such a light load?
I am betting you are airing bags to put truck at unloaded ride height. Drop the air in your bags to 5psi and raise the ball to where the trailer sets level and carry on.
Your truck is designed to set level when placing a load on it and allow the overloads to start working.
This is NOT squat! My 11 DRW is riding level with 4,50# pin. NO air bags.
* This post was edited 04/05/20 10:37am by Cummins12V98 *
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 04/05/20 10:30am Link  |  Quote  |  Print  |  Notify Moderator
7k trailer with a DRW? 10% tongue weight I don't think so.
Have any of you guys actually read what truck he has and the actual weight of his trailer???
This is what you need Lou if your ball height is not adjustable.
* This post was edited 04/05/20 10:36am by Cummins12V98 *
Page of 5
