RV.Net Open Roads Forum: Tech Issues: Brakes Stopped Working after CW Visit.
 > Brakes Stopped Working after CW Visit.
CA Traveler
The Western States
Posted: 04/05/20 09:25am Link  |  Quote  |  Print  |  Notify Moderator
ugeesta wrote:
Had warranty work done, one of which was to change a leaf spring out. When we received the trailer, I noticed it had a new breakaway switch in the pin. Not sure why but didn’t ask and was not part of the warranty work.
On the way out the truck wave me a warning to check the trailer wiring so I played with the pigtail and the brakes worked. I got the notice on and off an the way home.
Did you drive without the breakaway cable? Hence the brakes were on, overheated and likely now ruined? Sounds like it.
2014 Grand Cherokee Overland
Bob
ugeesta
Denver
Posted: 04/05/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
joebedford wrote:
What does "I have no brakes more than having brakes" mean?
It means the brakes would work intermittently. I’m going to try to clean the plug a little better an apply some dielectric grease to see if that helps
2018 GMC Seirra 3500 Denali SRW
2018 Jayco Talon 313t
2019 Polaris XP1000 Trail and Rocks edition
2016 Yamaha Grizzly EPS
1 wife & 5 cats
ugeesta
Denver
Posted: 04/05/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Yes/no. I pulled the breakaway cable and drove for about 30 feet. Just enough to see if the brakes worked.
Near Annett’s Mono Village, Bridgeport, CA
Posted: 04/05/20 11:06am Link  |  Quote  |  Print  |  Notify Moderator
You noticed the brake issue when? Five months ago?
Big Dog2
Alberta
Posted: 04/05/20 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem several years ago. It turned out to be a ground wire in the pigtail was loose. I recommend you check/tighten all the connections inside the pigtail. Hope your issue is resolved as easily as mine was. Good luck.
I am living proof that you are never too old to do something foolish.
Wherever I happen to park
Posted: 04/05/20 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
K Charles wrote:
Maybe they broke a wire when they dropped the axle.
If I had to guess I'd say the probability of this is in the 99+% range.
Home is where I park it.
ugeesta
Denver
Posted: 04/05/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Would that provide intermittent complete brake failure or just affect the single brake?...
wnjj
Cornelius, Oregon
Posted: 04/05/20 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
That depends upon if the broken or poor connection is between the plug and all of the brakes or just at one wheel. There needs to be a complete reliable connection from the plug to all brakes, including power and ground.
old guy
Oregon (pronounced Or e gun)
Posted: 04/05/20 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
if they put on a new break away switch they may have screwed up the wiring job and or connections. or the break away switch is faulty
opnspaces
San Diego Ca
Posted: 04/05/20 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
I would ask why there is a new breakaway switch on your trailer when they were supposed to change a leaf spring. The two are not related and you have a right to know what happened to your trailer that they felt they had to put a switch on. Their answer might give you a clue to why your brakes aren't working well. But regardless of that, if I was you I would be cutting out and redoing every connection from the umbilical cord to the each brake magnet.
Also many times the brake wires get chafed where they run through the inside of the axle and short to ground. If you do the connections over it would be a good idea to run new wires along the outside of the axles. Get some long zip ties and run the wire behind the axle to protect it from flying debris when driving down the road.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
